Help Center/ CodeArts Artifact/ User Guide/ Self-Hosted Repos 2.0/ Configuring Repository Permissions
Updated on 2025-10-11 GMT+08:00
By default, new users in self-hosted repos have no permissions. You need to add them to a project and assign roles to them. Each role has different permissions. You can view role permissions on the CodeArts Artifact permissions page and edit user permissions as needed.
  • By default, project administrators have all permissions and their permission scope cannot be modified.
  • Custom roles created in CodeArts Artifact do not have preset permissions. You can contact the project administrator to configure roles and permissions on corresponding resources.
  • By default, the project administrator, project manager, and test manager can assign permissions for other roles in self-hosted repos. If other roles can assign permissions, they can continue to manage permissions for other roles in self-hosted repos.
  • You have created a project.
  • You have added users to the CodeArts project and assigned roles to them. For details, see Adding Project Members.
  • To assign permissions to other roles in the self-hosted repo, you must have the Privilege Config permission. By default, the project administrator, project manager, and test manager roles have this permission.
Configuring Project-Level Permissions
  1. Log in as a user with the Privilege Config permission, and access the self-hosted repo.
  2. Choose Settings > General > Permissions from the navigation pane. The Permissions page is displayed.
  3. In the Roles area, click the role you want to configure permissions, select CodeArts Artifact on the right, and click Edit at the bottom of the page. In the displayed page, select or deselect the required permissions.
    Table 1 Project-level permissions
    Role/Operation
    Create a repository
    Edit a repository
    Delete a repository
    Restore
    Permanently delete
    Restore all
    Clear all
    Upload a package
    Download/View a package
    Delete/Redeploy uploaded packages
    Project manager
    Product manager
    Test manager
    Operation manager
    System engineer
    Committer
    Developer
    Tester
    Participant
    Viewer
    Project administrator
    • Tenant administrators (IAM user with the Tenant Administrator permissions) can manage all projects of a tenant. Project creators who are not tenant administrators have the permissions listed in the preceding table.
    • IAM users created without being added to any groups do not have permissions. Administrators can assign permissions to these users on the IAM console. Then users can use cloud resources in the account based on the assigned permissions.
    • Custom roles do not have preset permissions. You can contact the administrator to grant permissions for the resources needed for your role.
  4. Click Save.
Configuring Repository-Level Permissions
CodeArts Artifact allows you to configure permissions on all self-hosted repos in a project. For details, see Configuring Project-Level Permissions.
You can also configure permissions for a single self-hosted repo.
To add or remove permissions for self-hosted repo members, perform the following steps:
  1. Go to the self-hosted repo page and select the target repository from the list.
  2. Click Settings on the right of the page.
  3. Click the Repository Permissions tab. The roles in the current project are displayed.
  4. In the Roles area, select or deselect permissions of the target role, and click Save.
    • By default, created self-hosted repos connect with the role permission of Permissions in Settings in the project. Any changes made to these role permissions in Permissions will be synced to the repo's permissions.
    • If you do not change the repository permission of a role in the self-hosted repo, any changes made on the Permissions page will be synchronized to the repository permission of the self-hosted repo as well.
    • If you change the repository permission of a role directly in the self-hosted repo, any changes made on the Permissions page will not be synchronized to the repository permission of the self-hosted repo. You need to change the permission of the role in the repo itself.
