- What's New
- Function Overview
Getting Started
- Uploading Software Packages to Release Repos
- Uploading Components to Maven Repository
- Releasing/Obtaining a Maven Component via a Build Task
- Releasing/Obtaining an npm Component via a Build Task
- Releasing/Obtaining a Go Component via a Build Task
- Releasing/Obtaining a PyPI Component via a Build Task
- Uploading/Obtaining an RPM Component Using Linux Commands
- Uploading/Obtaining a Debian Component Using Linux Commands
User Guide
- CodeArts Artifact User Guide
- Release Repos 2.0
- Self-Hosted Repos 2.0
- Release Repos 1.0
- Self-Hosted Repos 1.0
- Whitelist for All Accounts
Best Practices
- CodeArts Artifact Best Practices
- Releasing Maven Components and Archiving to a Self-Hosted Repo
- Batch Migrating Maven/npm/PyPI Components to a Self-Hosted Repo
- API Reference
- Release Repo
Self-Hosted Repo
- How Do I Upload Snapshots to a Maven Repository?
- How Do I Pull Components from a Maven Repository?
- Can I Call Software Packages in Self-Hosted Repos During Local Builds?
- What Should I Do With Error Code 500 When Uploading Maven Package for a Gradle Build?
- Why Did the Dependency WAR or JAR Files Fail to Be Downloaded?
- Why Is Error 401 Returned When Uploading Maven Components to Self-Hosted Repos?
On this page
Show all
Help Center/
CodeArts Artifact/
User Guide/
Self-Hosted Repos 1.0/
Managing a Self-Hosted Repo 1.0/
Checking Basic Information and Adding Path Patterns
- Go to the self-hosted repo page. In the left pane, click the name of the target repository to be edited.
- Click Settings on the right of the page to view the basic information about the repository.
- Edit the repository description as required and click Submit.
On the basic information page, the repository name, package type, project, and version policy cannot be modified.
On the Basic Information page of the repository, enter the path and click
to add paths for Maven, npm, Go, PyPI, RPM and Conan repositories.
Click
to delete paths.
Parent topic: Managing a Self-Hosted Repo 1.0
