- What's New
- Function Overview
Getting Started
- Uploading Software Packages to Release Repos
- Uploading Components to Maven Repository
- Releasing/Obtaining a Maven Component via a Build Task
- Releasing/Obtaining an npm Component via a Build Task
- Releasing/Obtaining a Go Component via a Build Task
- Releasing/Obtaining a PyPI Component via a Build Task
- Uploading/Obtaining an RPM Component Using Linux Commands
- Uploading/Obtaining a Debian Component Using Linux Commands
User Guide
- CodeArts Artifact User Guide
- Release Repos 2.0
- Self-Hosted Repos 2.0
- Release Repos 1.0
- Self-Hosted Repos 1.0
- Whitelist for All Accounts
Best Practices
- CodeArts Artifact Best Practices
- Releasing Maven Components and Archiving to a Self-Hosted Repo
- Batch Migrating Maven/npm/PyPI Components to a Self-Hosted Repo
- API Reference
- Release Repo
Self-Hosted Repo
- How Do I Upload Snapshots to a Maven Repository?
- How Do I Pull Components from a Maven Repository?
- Can I Call Software Packages in Self-Hosted Repos During Local Builds?
- What Should I Do With Error Code 500 When Uploading Maven Package for a Gradle Build?
- Why Did the Dependency WAR or JAR Files Fail to Be Downloaded?
- Why Is Error 401 Returned When Uploading Maven Components to Self-Hosted Repos?
Viewing a Component
Viewing Components in the Repo View
After you access the self-hosted repo, the repo view is displayed by default. The uploaded components are stored in their respective folders within this view.
- Go to the self-hosted repo and click
in front of the repository and folder to find the component.
- Click the component name. The repository details and checksums page are displayed.
Click
in the Details and Checksums tab to copy the information. In the search box, find the target component using the pasted information.
Viewing Components in the Version View
A self-hosted repo displays different component types by version. In Version View tab page, you can filter and display artifact packages by name and version number, and sort files by their update time.
- Go to the self-hosted repo page.
- Select Version View in the upper left corner of the page and click a repository name in the list on the left. The package version list is displayed. For details about how to set versions for different components, see Uploading/Downloading Components on the Self-Hosted Repo Page.
- Self-hosted repos store software packages of different versions with the same name in the same file. Click a name in the Package Name column. The overview information about the latest version of the software package is displayed.
- Click a number in the Versions column. The version list of the software package is displayed.
Click a number in the Version No. column. The Overview and Files pages of the software package are displayed. In the Files tab, click a name in the File Name column. The path of the software package is displayed.
