Updated on 2025-10-11 GMT+08:00
Creating a Repository
If you use this service for the first time, you need to create a repository. Self-hosted repos are divided into local repositories and virtual repositories.
Local Repository: An actual physical repository hosted on the server, where you can upload different types of artifacts.
Virtual Repository: You can configure proxy sources in a virtual repository to connect with local third-party repositories. A virtual repository also offers local repository functions and provides a unified entry to make setup easier for you.
Docker registry and CocoaPods repository currently are only available in the AP-Singapore region.
After a repository is created, its name and project cannot be changed.
  1. Access Self-hosted Repos.
  2. Choose Artifact > Self-hosted Repos from the navigation pane. Click Create Repository in the upper-right corner of the page. The Create Repository page is displayed.
  3. Configure the basic information by referring to Table 1 and Table 2.
    Table 1 Parameters for configuring a repository
    Item
    Mandatory
    Repository Type
    Yes
    You can choose Local Repo or Virtual Repo.
    • A local repository is hosted on the server and is a physical repository that stores artifact data.
    • A virtual repository combines local and proxy repositories, offering a single, unified entry for accessing artifacts.
    Repository Name
    Yes
    Enter up to 20 characters. Only letters, digits, underscores (_), hyphens (-), and periods (.) are supported.
    After a repository is created, its name cannot be changed.
    Package Type
    Yes
    Local repository supports Maven, npm, RPM, PyPI, Go, Debian, Conan, NuGet, CocoaPods, Generic, OHPM, and Docker artifacts.
    Virtual repository supports Maven, npm, PyPI, Conan, OHPM, and Docker artifacts.
    The parameters vary based on the package type. Configure them by referring to Table 2.
    Project
    Yes
    Choose a project to associate with the new repository. After the settings are complete, the project to which the repository belongs cannot be changed.
    No
    Enter up to 200 characters.
    Table 2 Parameters of different package types
    Package Type
    Mandatory
    Maven
    Associated Projects
    Yes
    Select the name of the project to be associated from the drop-down list.
    Include Patterns
    No
    Enter rules to specify paths allowed for artifact uploads. By default, all artifact paths are allowed. During builds, only Maven files whose paths start with the preceding path prefix can be uploaded to the self-hosted repo.
    For example, if you add demo, that is, demo/**/*, all paths starting with demo/ are allowed.
    You can click + to add multiple inclusion rules.
    Exclude Patterns
    No
    Enter rules to specify paths not allowed for artifact uploads. During builds, Maven files whose paths start with the preceding path prefix cannot be uploaded to the self-hosted repo.
    You can click + to add multiple exclusion rules.
    Version Policy
    Yes
    Two repositories will be generated: Release and Snapshot. The Release repository is selected by default and the Snapshot repository can also be selected as required.
    • The Release repository is used to store release versions with stable functions that will no longer be updated.
    • The Snapshot repository is used to store development versions with unstable functions in the development stage.
    npm
    Include Patterns
    No
    Enter rules to specify paths allowed for artifact uploads. During builds, only npm files whose paths start with the preceding path prefix can be uploaded to the self-hosted repo.
    Exclude Patterns
    No
    Enter rules to specify paths not allowed for artifact uploads. During builds, npm files whose paths start with the preceding path prefix cannot be uploaded to the self-hosted repo.
    RPM
    Include Patterns
    No
    Enter rules to specify paths allowed for artifact uploads. During builds, only RPM binary files whose paths start with the preceding path prefix can be uploaded to the self-hosted repo.
    Exclude Patterns
    No
    Enter rules to specify paths not allowed for artifact uploads. During builds, RPM binary files whose paths start with the preceding path prefix cannot be uploaded to the self-hosted repo.
    PyPI
    Include Patterns
    No
    Enter rules to specify paths allowed for artifact uploads. During builds, only PyPI dependencies in which the name value in the setup.py file matches the preceding path prefix can be uploaded to the self-hosted repo.
    Exclude Patterns
    No
    Enter rules to specify paths not allowed for artifact uploads. During builds, PyPI dependencies in which the name value in the setup.py file matches the preceding path prefix cannot be uploaded to the self-hosted repo.
    Go
    Include Patterns
    No
    Enter rules to specify paths allowed for artifact uploads. During builds, only Go files whose paths start with the preceding path prefix can be uploaded to the self-hosted repo.
    Exclude Patterns
    No
    Enter rules to specify paths not allowed for artifact uploads. During builds, Go files whose paths start with the preceding path prefix cannot be uploaded to the self-hosted repo.
    Conan
    Include Patterns
    No
    Enter rules to specify paths allowed for artifact uploads. During builds, only Conan files whose paths start with the preceding path prefix can be uploaded to the self-hosted repo.
    Exclude Patterns
    No
    Enter rules to specify paths not allowed for artifact uploads. Conan files whose paths start with the preceding path prefix cannot be uploaded from a local client to the self-hosted repo.
    NuGet
    Include Patterns
    No
    Enter rules to specify paths allowed for artifact uploads. During builds, only NuGet files whose paths start with the preceding path prefix can be uploaded to the self-hosted repo.
    Exclude Patterns
    No
    Enter rules to specify paths not allowed for artifact uploads. NuGet files whose paths start with the preceding path prefix cannot be uploaded from a local client to the self-hosted repo.
    CocoaPods
    Include Patterns
    No
    Enter rules to specify paths allowed for artifact uploads. During builds, only CocoaPods files whose paths start with the preceding path prefix can be uploaded to the self-hosted repo.
    Exclude Patterns
    No
    Enter rules to specify paths not allowed for artifact uploads. During builds, CocoaPods files whose paths start with the preceding path prefix cannot be uploaded to the self-hosted repo.
    Generic
    Include Patterns
    No
    Enter rules to specify paths allowed for artifact uploads. You can click + to add multiple paths. During builds, only Generic files whose paths start with the preceding path prefix can be pushed to the self-hosted repo.
    Exclude Patterns
    No
    Enter rules to specify paths not allowed for artifact uploads. During builds, Generic files whose paths start with the preceding path prefix cannot be uploaded to the self-hosted repo.
    During builds, Generic files whose paths start with the preceding path prefix cannot be pushed to the self-hosted repo.
    OHPM
    Include Patterns
    No
    Enter rules to specify paths allowed for artifact uploads. During builds, only OHPM files whose paths start with the preceding path prefix can be pushed to the self-hosted repo.
    Exclude Patterns
    No
    Enter rules to specify paths not allowed for artifact uploads. During builds, OHPM files whose paths start with the preceding path prefix cannot be uploaded to the self-hosted repo.
    Docker
    Include Patterns
    No
    Enter rules to specify paths allowed for artifact uploads. During builds, only image files whose paths start with the preceding path prefix can be pushed to the self-hosted repo.
    Exclude Patterns
    No
    Enter rules to specify paths not allowed for artifact uploads. Image files whose paths start with the preceding path prefix cannot be pushed to the self-hosted repo.
  4. Click OK. The new repository displays in the repository list on the left.
