Configuring Permissions (New)
In CodeArts Artifact, different project roles have different permissions. You can view the default permissions of each project role on the permissions management page of CodeArts Artifact and adjust the role permissions as required.
- By default, project administrators have all permissions and their permission scope cannot be modified.
- Custom roles created in CodeArts Artifact do not have preset permissions. You can contact the project administrator to configure roles and permissions on corresponding resources.
- By default, the project administrator, project manager, and test manager roles have the Privilege Config permission. They can assign other roles permissions for the release repos. If other roles have the Privilege Config permission, they can continue to manage permissions for different roles in release repos.
- You have created a CodeArts project.
- You have added users to the CodeArts project and assigned roles to them. For details, see Adding Project Members.
- To assign permissions to other roles in the release repos, you must have the Privilege Config permission. By default, the project administrator, project manager, and test manager roles have this permission.
Setting Permissions
- A user with the Privilege Config permission accesses the Release Repos.
- Click Set Project Permissions, as shown in the following figure.
- In the Roles area, select the role to configure. On the right of the page, choose CodeArts Artifact. The following table lists the default permissions of each role in the release repos.
Table 1 Default permissions of each role Role/Operation
Change Package Status
Upload
Delete/Restore (Test Package)
Delete/Restore (Production Package)
Edit (Test Package)
Create Folder
Download
Restore All
Clear All
Project manager
Product manager
Test manager
Operation manager
System engineer
Committer
Developer
Tester
Participant
Viewer
CI/CD engineer
Project administrator
- Click Edit at the bottom of the page and select or deselect permissions as required.
- Click Save.
Each role can access the Release Repos and perform their authorized operations.
