Help Center/ Cloud Firewall/ User Guide/ Log Audit/ Protection Log Overview
Updated on 2025-08-05 GMT+08:00
This section describes the following content:
Log Storage Mode
Function
Storage Duration
Billing Mode
Access Mode
Log Field Description
Log query
7 days
Free
Automatic access
Querying Logs
Log management
1 to 365 days
Separate billing by traffic
You need to manually connect to LTS. For details, see Configuring Logs.
For details about how to use the LTS log function, see Log Management Description.
Log Types
The following types of logs are provided:
  • Attack event logs: The events detected by attack defense functions, such as IPS, are recorded.
  • Access control logs: All traffic that matches the access control policy are recorded.
  • Traffic logs: All traffic passing through the firewall is recorded.
SecMaster supports one-click access to CFW log data. There is a delay in log reporting. If you let SecMaster access the logs of a CFW instance that was newly purchased, you can view the CFW logs on SecMaster the next day.
Handling Improper Blocking
  • If improper blocking is recorded in access control logs, your normal workloads may be blocked by IPS. In this case, check the policy configuration. For details about how to modify protection rules, see Managing Protection Rules. For details about how to modify the blacklist and whitelist, see Editing the Blacklist or Whitelist.
  • If improper blocking is recorded in attack event logs, your normal workloads may be blocked by IPS.
Function
Configuration Method
Configuring logs
Interconnect logs with LTS and create a log group and a log stream.
Configuring Logs
Modifying log storage duration
(Optional) By default, logs are stored for seven days. You can set the storage duration in the range 1 to 365 days.
Changing the Log Storage Duration
Log search and analysis
(Optional) Use proper log collection functions, efficient search methods, and professional analysis tools to implement comprehensive monitoring and refined management of your system and applications.
For details, see Log Search and Analysis.
Log visualization
(Optional) Visualize log data in tables and charts.
See Log Visualization.
Configuring alarm rules
(Optional) Monitor keywords in logs. Collect statistics on the occurrences of keywords in logs within a specified period to monitor the service running status in real time.
For details, see Log Alarms.
Viewing log fields
Learn the meaning of fields in a log.
References
