Updated on 2026-11-10 GMT+08:00
Creating a Security Report
You can obtain security reports to keep yourself updated about asset security status. CFW will send the log reports to you based on the specified time range and receiving method.
This section describes how to create a security report.
Notes and Constraints
  • Up to 10 security reports can be created for a CFW instance.
  • A security report is retained for only three months. You are advised to periodically download security reports for audit.
  • A security report of the Custom type cannot be modified after being created. To modify it, delete it and create a new one.
  1. Log in to the CFW console.
  2. Click in the upper left corner of the management console and select a region.
  3. (Optional) Switch to another firewall instance. If there are multiple firewall instances, you can select a desired instance from the drop-down list in the upper left corner of the page.
  4. In the navigation tree on the left, choose System Management > Security Report.
  5. Click Create Template. On the Create Template page, configure report parameters.
    Table 1 Parameters of the security report template
    Report Name
    Name of the custom security report It must meet the following requirements:
    • Only uppercase letters (A to Z), lowercase letters (a to z), numbers (0 to 9), hyphens (-), and underscores (_) are allowed.
    • It can contain 1 to 255 characters.
    Report Type
    • Daily
      Statistical period: 00:00 to 24:00 daily
      A report will be sent to the recipients the day after it is generated.
    • Weekly
      Statistical period: 00:00 on Monday to 24:00 on Sunday
      A report will be sent to the recipients at the specified time after it is generated.
    • Custom: Customize a time range.
      Statistical Period: Configure a statistical period for your report.
      A report will be sent to the specified recipients after it is generated.
    Statistical Period
    If Report Type is set to Custom, you need to set Statistical Period.
    Report Schedule
    If Report Type is set to Daily or Weekly, you need to set the report sending time. By default, the log report of the previous statistical period is sent.
    • To ensure correctness, the report sending time may be delayed.
    • If Report Type is set to Custom, the report is automatically sent after being generated.
    Recipient Group
    If Send Report To is set to SMN topic, you need to set a recipient group.
    Select a topic from the drop-down list to configure the endpoints for receiving the log report.
    To create a topic, click View Topic to go to the SMN console. Perform the following operations:
    1. Create a topic.
    2. Add one or more subscriptions to the topic. You will need to provide a phone number, email address, or HTTP/HTTPS endpoint to receive alarm notifications. For details, see Adding a Subscription.
    3. Confirm the subscription.
    Send Report To
    Security report recipients.
    • SMN topic: Configure report recipients by topic.
    • Do not send: The report is not sent by email.
  6. Click OK. A security report is created.
Follow-up Operations
For details about how to download and view security reports, see Viewing/Downloading a Security Report.
References
For details about how to enable, disable, modify, or delete a security report, see Managing Security Reports.
