Configuring an Enterprise Router
This section describes how to associate a firewall with an enterprise router and configure traffic diversion.
How to Configure
The process of configuring an enterprise router is as follows.
A firewall has been created.
- Default Route Table Association, Default Route Table Propagation, and Auto Accept Shared Attachments must be disabled.
- Only the professional edition supports inter-VPC firewall protection.
- Click
in the upper left corner of the management console and select a region or project.
- In the navigation pane on the left, click
and choose . The Dashboard page will be displayed.
- (Optional) Switch to another firewall instance. Select a firewall from the drop-down list in the upper left corner of the page.
- In the navigation pane, choose Assets > Inter-VPC Border Firewalls.
- Click Configure Enterprise Router. On the displayed page, add attachments to an enterprise router. For details about the attachment types that can be added, see Attachment Overview.
Assume you want to protect two VPCs. (At least two VPC attachments are required to connect the two VPCs to the enterprise router.) For details, see Adding VPC Attachments to an Enterprise Router.
- Add at least three connections, for example, the firewall connection cfw-er-auto (automatically generated after the firewall is created), the VPC1 connection vpc-1, and the VPC2 connection vpc-2.
- To use the enterprise router of account A to protect VPCs under account B, share the router with account B, and add an attachment in account B. For details, see Creating a Sharing. Subsequent configurations should still be performed on account A.
- Create two route tables to connect to the firewall and the VPC to be protected, respectively.
Click the Route Tables tab. Click Create Route Table.
Create a route table, as shown in Figure 2. For more information, see Route table parameters.
Table 1 Route table parameters Parameter
Example Value
Name
Route table name.
It must meet the following requirements:- Must contain 1 to 64 characters.
- Can contain letters, digits, underscores (_), hyphens (-), and periods (.).
er-rlb-4cd1
Route table description
Tag
During the route table creation, you can tag the route table resources. Tags identify cloud resources for purposes of easy categorization and quick search.
For details about tags, see Tag Overview.
- Configure the association and routing.
- Select the route table to be connected to the VPC. Click the Associations tab and click Create Association.
For more information, see Association parameters.Figure 3 Creating an association
- Create a route for the route table. Click the Routes tab and click Create Route. You can create one or more routes as needed.
Create a route table, as shown in Figure 4. For more information, see Route parameters.
Table 3 Route parameters Parameter
Example Value
Destination
Set the destination address.
It can be a VPC CIDR block or subnet CIDR block.
NOTE:If your ECS is bound to an EIP, you need to specify the network segment when configuring the route. The value 0.0.0.0/0 is not allowed.
192.168.2.0/24
Attachment Type
Select VPC.
VPC
Next Hop
Select the VPC attachment of the firewall.
er-Inspection
- Configure the association and propagation.
- Select the route table to be connected to the firewall. Click the Associations tab and click Create Association.
Figure 5 Creating an association - Create a propagation for the route table. Click the Propagations tab and click Create Propagation.
For more information, see Propagation parameters.
Figure 6 Creating a propagationTable 5 Propagation parameters Parameter
Example Value
Attachment Type
Select VPC.
VPC
Select an item from the Attachment drop-down list.
er-attach-02
- After a propagation is created, its route information will be extracted to the route table of the enterprise router, and a propagation route will be generated. In the same route table, the destinations of different propagation routes may be the same, and cannot be modified or deleted.
- You can add static routes for the attachments in a route table. The destinations of static routes in a table must be unique, and can be modified or deleted.
- If a static route and a propagation route in the same route table happen to use the same destination, the static route takes effect first.
Verifying Configurations
- You have completed configuration.
- Each of the two VPCs has an ECS.
Method
Ping ECSs in the VPC from each other to check whether they can properly communication if there is no traffic passing through the firewall.
Troubleshooting
- Check whether the two route tables of the enterprise router are correctly configured. For details, see 8 and 9.
- Check whether the default route table of the VPC directs routes to the enterprise router.
1. In the service list, click Virtual Private Cloud under Networking. In the navigation pane, choose Route Tables. In the Name/ID column, click the route table name of the VPC to be protected.
2. Check whether there is a route whose Next Hop Type is Enterprise Router. If there are no such routes, click Add Route. The following table describes the parameters.
Table 6 Route parameters Parameter
Example Value
Destination
Destination CIDR block.
A route destination must be unique, and cannot overlap with any subnets in the VPC.
NOTE:The value cannot conflict with existing routes or subnet CIDR blocks in the VPC.
192.168.0.0/16
Next Hop Type
Select Enterprise Router from the drop-down list.
Next Hop
Select a resource for the next hop.
Only the resources of the next hop type you selected are displayed in the drop-down list.
er-01
(Optional) Supplementary information about the route.
NOTE:Enter up to 255 characters. Angle brackets (< or >) are not allowed.
