Managing Service Groups
A service group is a collection of services (protocols, source ports, and destination ports). You can reference a service group in an access rule to implement unified traffic control for that group. The updates of the service group will be automatically synchronized to all the policies associated with it. This helps you quickly modify policies and avoid repeated configuration, improving O&M efficiency.
- For adding a user-defined service group and services:
- A service group can have up to 64 services.
- A firewall instance can have up to 512 service groups.
- A firewall instance can have up to 900 services.
- You can only view predefined service groups, but cannot add services to it, or modify or delete it.
- The service group referenced by a protection rule cannot be deleted. Modify or delete the rule first.
Adding a User-defined Service Group
- Log in to the CFW console.
- Click
in the upper left corner of the management console and select a region or project.
- (Optional) Switch to another firewall instance. Select a firewall from the drop-down list in the upper left corner of the page.
- In the navigation pane, choose .
- Click the Service Groups tab. Click Add Service Group and configure parameters in the Add Service Group area. Enter the service group name and description.
Table 1 Service group parameters Parameter
Service Group Name
Name of a service group
Usage and application scenario
Services
- Protocol: Select a protocol from TCP, UDP, and ICMP.
- Source Port: Set the source port to be allowed or blocked. You can configure a single port or consecutive port groups (example: 80-443).
- Destination Port: Set the destination port to be allowed or blocked. You can configure a single port or consecutive port groups (example: 80-443).
- Description: Usage and application scenario of the service group
- Confirm the information and click OK.
After adding a service group for the first time, you need to add services to it. For details, see Adding a Service to a User-defined Service Group.
A service group takes effect only after it is set in a protection rule. For more information, see Configuring Protection Rules to Block or Allow Internet Border Traffic.
- Click
- Click the Service Groups tab. Click the name of a service group. The Service Group Details dialog box is displayed.
- Click Add Service.
Table 2 Adding a service Parameter
Example Value
Protocol
Its value can be TCP, UDP, or ICMP.
TCP
Source Port
Source ports to be allowed or blocked. You can configure a single port or consecutive port groups (example: 80-443).
If Protocol is set to ICMP, you do not need to specify any port number.
80
Destination Port
Destination ports to be allowed or blocked. You can configure a single port or consecutive port groups (example: 80-443).
80
- You can click Add to add multiple services.
Viewing a Predefined Service Group
CFW provides predefined service groups, including Web Service, Database, and Remote Login and Ping, suitable for protecting web services, databases, and servers, respectively.
- Click
- Click the Service Groups tab. Click the Pre-defined Service Groups tab and click the name of a service group. On the details page that is displayed, view the service group information.
Deleting a User-defined Service Group
Deleted service groups cannot be restored. Exercise caution when performing this operation.
- Click
- Click the Service Groups tab. In the Operation column of a service group, click Delete.
- In the displayed dialog box, confirm the information, enter DELETE, and click OK.
Related Operations
- Exporting service groups: Click Export above the list and select a data range.
- Deleting services in batches: On the Service Groups tab, select services and click Delete above the list.
