What Do I Do If Two Languages Are Displayed on the Case Page After Language Switching
Symptom
After you switch the language, the language of some GUI elements is switched successfully, but the language of some GUI elements remains unchanged, as shown in 1.
Analysis
The Case 2.0 is developed based on AppCube. If the language environment of the Case 2.0 is different from that of AppCube, this problem occurs.
Solution
Switch the AICC language to another language and then switch it back. In this way, the language environment of the Case 2.0 becomes consistent with that of AppCube.
