Help Center/
Customer Engagement Center/
User Guide/
Tenant Administrator Guide/
Managing Cases/
Case Handling/
Searching for Cases
Updated on 2025-01-23 GMT+08:00
Searching for Cases
- Sign in to the AICC, choose , enter a case title, and press Enter to search for the case.
- Click Advanced Search and set advanced search criteria to search for cases.
Figure 1 Advanced Search
- Filter cases by tab page. You can view cases on the Todo, Unassigned, What I'm concerned about, What I created, Processed, or All tab page.
Figure 2 Tab page
- Click
to export cases based on filter criteria.
- Click
to customize the view. Select the columns to be displayed in the list. To restore the default configuration, click Reset.
Figure 3 Column configuration
Parent topic: Case Handling
