On this page
Show all
Case Type
Updated on 2025-01-23 GMT+08:00
  1. Sign in to the AICC, choose Configuration Center > Case Configuration 2.0 > Case Configuration > Case Type, and click .
    Figure 1 Create
  2. On the Create page, enter case type information and click Save.
    Table 1 Case type parameters
    Case Type Name
    Enter a case type name, for example, Complaint.
    Case Type Description
    Enter a case type description, for example, Complaint content, Complaint target, or Complaint source.
    Cascader
    Select an upper-level case type.
    Case Template
    Select a value from the drop-down list.
    Case Context Template
    Associate a case content template.
    Case Process
    Add case statuses.
    Strictly Follow the Status Sequence
    Enable or disable this function. If this function is enabled, the case can only be handled step by step. If disabled, the case status can be transitioned to any status as required.
    Verify task status
    Enable or disable this function. If this function is enabled, the status of the associated tasks is verified when the case is closed. If disabled, the status of the associated tasks is not verified.
  3. After the case type is created, you can switch its status to to enable it. You can select only an enabled case type when creating a case on the Case 2.0 > Case Workbench page.
    Figure 2 Enabling a case type
  4. After a case type is enabled, synchronize it to the Metadata Management page.
    Figure 3 Metadata Management
  5. If the case type has not been referenced, you can switch its status to to disable the case type. After the case type is disabled, you can edit or delete the case type.
