Case Content Template
- The Case 2.0 feature has been enabled for the tenant space.
 - You have the Case Configuration permission.
 - An enabled case template is available.
- Sign in to the AICC and choose .
    Figure 1 Case Template Content page
     - Click . In the Case Content Template Information area, set Content Template Name and Associated Case Template, and click Save.
    Figure 2 Case Content Template Information area
    Table 1 Parameters in the Case Content Template Information area Parameter
Mandatory.
Select a value from the drop-down list. The options are case templates on the page. For details about how to create a case template, see Case Template.
 - Click . On the editing page, enter case template information.
    Figure 3 Edit button
    Figure 4 Case Template Info area
    Table 2 Parameters in the Case Template Info area Parameter
Title
Case title. The value can contain a maximum of 128 characters.
Content Description
Case content description.
Priority
- Low
 - Medium
 - High
 - Critical
Source
- Voice
 - webchat
Deadline
Case deadline.
Associated Customer
- The options are customers in the customer center. You can sign in to the AICC as a tenant administrator and choose to view customers. For details, see Managing the Customer Center.
 - You can directly create a customer. For details, see Creating a Customer.
Assignment Mode
- If this parameter is set to Manual, you can assign the case to a skill queue or an agent.
 - If this parameter is set to Auto, the case will be assigned based on the case assignment rule on the page. For details, see Case Assignment Rule.
Owner
The options are all employees in the tenant space. If you select Claim, the owner is the case creator by default.
