Help Center/
Customer Engagement Center/
User Guide/
Tenant Administrator Guide/
Configuring the Knowledge Base/
Managing Consultation Tables/
Managing Consultation Table Templates
Updated on 2025-01-23 GMT+08:00
- The AppCube feature has been enabled for the tenant space, and the AICC has been connected to AppCube. The Knowledge base feature has been enabled.
- You have the and menu permissions.
- You have customized consultation table fields.
- Sign in to the AICC as a tenant administrator and choose .
- Click Configure to access AppCube and configure consultation tables.
Figure 1 Config Center
- Choose . The consultation table list page is displayed.
Figure 2 Model
- Select a consultation table to which a field needs to be added and click New to add a field. The consultation tables are preset and contain two fields by default.
- Select a field type and configure field details as prompted. The field name is automatically filled in based on the label and can be modified.
- Click Next to save the new field.
Figure 3 Consultation table template list
You can click Configure to customize consultation table fields. For details, see Prerequisites.
- Click Add. On the page that is displayed, configure a consultation table template.
Figure 4 Adding a consultation table template
- Template name: Name of the consultation table template. This parameter is mandatory.
- Consult table: Select the required consultation table. This parameter is mandatory.
- Template status: Status of the consultation table template. This parameter is mandatory. The options are as follows:
- Draft: Multiple draft consultation table templates can be created for a consultation table.
- Enabled: Only one enabled consultation table template can be created for a consultation table.
- Template description: Description of the consultation table template.
- List of consultation table fields: The values are automatically generated after the required consultation table is selected.
- Select a field and click Modify. On the page for editing extended attributes, configure extended attributes of the consultation table field.
Figure 5 Editing extended attributes
- Field: Read-only.
- Display name: Read-only.
- Displayed or Not: Whether to display the field in the consultation table field list.
- Search Criterion or Not: Whether the field is a search criterion in the consultation table field list.
- Anonymized or Not: Whether to anonymize the field in the consultation table field list. Set Anonymized or Not to Yes for fields that contain personal data and sensitive data.
- Click OK to complete the configuration of extended attributes and return to the page for adding a template.
- (Optional) To change the display position of a consultation table field, select the field and click Move up or Move Down.
- Click Save.
Follow-up Procedure
You can perform the following operations after you select consultation table templates:
- Click Delete to delete the consultation table templates in batches.
- Click Modify to modify template parameters except Consult table. The template status can be changed to Discarded.
Parent topic: Managing Consultation Tables
