Help Center/
      Customer Engagement Center/
        User Guide/
        Tenant Administrator Guide/
        IVR Journey Analysis/
      Optimization Suggestion
        Updated on 2025-01-23 GMT+08:00
Based on the key pressing track and number of key pressing times on the user side, optimization suggestions are provided for the current IVR flow, which can be used as a reference for flow optimization.
- You have the IVR Analysis > Optimization menu permission.
 - The IVR analysis and intelligent IVR features have been enabled for the tenant space.
 - The chatbot flow to be analyzed has an access code.
 - The chatbot flow to be analyzed has call records in the query time range, and the call records have been collected by a scheduled task. (The scheduled task is executed every hour.)
    Figure 1 Access Code Settings
- Sign in to the AICC and choose .
    Figure 2 Optimization
     - Set the chatbot, flow version, and query time range and press Enter.
 - Enter a node name in the text box on the left to search for the node.
 - Click the Voice broadcast sequence optimization tab to view Current Voice Playback Key Usage Statistics and Recommended voice broadcast sequence on the right.
 - Click the Voice definition optimization tab to view Repeated Listening Times and Optimization Suggestions.
   Parent topic: IVR Journey Analysis
