Help Center/
      Customer Engagement Center/
        User Guide/
        Tenant Administrator Guide/
        Robot Management and Configuration Guide/
        Configuring the Preconfiguration Intelligent Flows/
        Releasing Flows and Testing Calls/
      Call Tests
        Updated on 2025-01-23 GMT+08:00
Call Tests
- Choose .
 - Click Add to add an access code. Set required information, select the flow to be tested, and click Confirm.
 - Click Test Call in the last column of the desired access code.
 - In the dialog box that is displayed, enter the information to perform the test.
   Parent topic: Releasing Flows and Testing Calls
