Help Center/
Customer Engagement Center/
User Guide/
Tenant Administrator Guide/
Robot Management and Configuration Guide/
Configuring the Preconfiguration Intelligent Flows/
Configuring the Intelligent Information Matching Flow/
Response Templates Returned to the Semantic Recognition Invoker
Updated on 2025-01-23 GMT+08:00
The JSON format of the response template PromptText in the second response diagram element in the information matching flow is fixed. Ensure that the referenced parameter name is the same as the variable name defined in the flow.
- Choose
next to the information matching flow. and click
- Click the Response diagram element in the lower part to view the response template name.
- Choose .
- Click Edit next to the template described in 2.
- On the Edit Template page, modify the JSON content as required. Ensure that the parameter names in the JSON file are the same as the variable names defined in the information matching flow.
Parent topic: Configuring the Intelligent Information Matching Flow
