Help Center/
Customer Engagement Center/
User Guide/
Tenant Administrator Guide/
Robot Management and Configuration Guide/
Operator: Configuring a Common IVR/
Diagram Elements/
Response (Expired and Not Recommended)
Updated on 2025-01-23 GMT+08:00
Diagram Element
Parameter Description
The following figure shows the parameters of the Robot Reply diagram element.
The parameters are described as follows:
- Node Name: Enter a diagram element name. The value can be customized.
Typical Application Scenario
This diagram element is used with the Ringing diagram element.
Parent topic: Diagram Elements
