Survey
Diagram Element
Parameter Description
The following figure shows the parameters of the questionnaire diagram element.
The parameters are described as follows:
- Node Name: name displayed on the diagram element, which can be customized.
Condition Branch Description
Condition Branch |
Description |
Usage |
SYSERROR_INNER |
ODFS internal error |
Triggered when an unknown error occurs in the ODFS. If no option is selected, the flow goes to the exception handling flow. |
Typical Application Scenario
The questionnaire diagram element is used only when an automatic outbound call task needs to be associated with an IVR survey flow. After an intelligent outbound call task is started, if the IVR flow associated with the outbound call task contains the questionnaire diagram element, the survey content specified for the outbound call task is played to the user.
