/chatbot/rest/tuc/v1/qualityInspection
Function
Intelligent training interface. After the training model is deployed and trained on the LODAS, the business interface in the intelligent IVR is invoked to send the user voice text information to the LODAS and obtain the scoring result from the intelligent engine. With the help of intelligent capabilities, an integrated system is built to implement capabilities such as customer chatbot simulation call training, automatic evaluation of reply accuracy, and automatic evaluation of operation accuracy. The following are implemented to improve work efficiency from the perspectives of employees, systems, and operations: pre-job tests and appraisals for new employees, training and appraisals for key and difficult business capabilities, job rotation training and appraisals for on-the-job employees, and reinstatement training and appraisals for employees awaiting job assignment.
Input Parameters
        Parameter  |
        Type  |
        Mandatory (Yes/No)  |
        Description  |
        language  |
        String  |
        Yes  |
        Language. The options are as follows: zh_CN: Chinese en_US: English  |
        channelType  |
        String  |
        Yes  |
        Inspection type. Training scoring: exam.  |
        speeches  |
        JSON string  |
        Yes  |
        Dialog content to be scored. If channelType is set to exam, the value of this parameter is the question ID and agent's answer. The following is an example. "speeches": "{\"examID\":\"jsex001\",\"speech\":\"*******\"}" Method of using variables: "speeches": "{\"examID\":\"${examID}\",\"speech\":\"${speech}\"}"  |
        callTime  |
        Long  |
        Yes  |
        Dialog timestamp, accurate to seconds. In the training scoring scenario, set the timestamp to -1, which is meaningless.  |
Output Parameters
        Parameter  |
        Type  |
        Description  |
        examResponse  |
        ExamResponse  |
        Training scoring result, which is returned during training scoring.  |
        qiResponse  |
        QiResponse  |
        Inspection score result, which is returned for common inspection. (In the inspection scoring scenario, this parameter is not used currently.)  |
        Parameter  |
        Type  |
        Description  |
        examId  |
        String  |
        Question ID.  |
        score  |
        Integer  |
        Exam score (excluding sensitive words).  |
        answerRules  |
        List <Object>  |
        Answer rules and score details.  |
        sensitiveWordRules  |
        sensitiveWordRuleMatch  |
        Sensitive words involved in answers and points deducted.  |
        Parameter  |
        Type  |
        Description  |
        positiveAnswer  |
        String  |
        Answer to the positive assessment point.  |
        positiveWeight  |
        Float  |
        Weight of the positive assessment point.  |
        positiveScore  |
        Float  |
        Score of the positive assessment point.  |
        negativeAnswer  |
        String  |
        Answer to the negative assessment point.  |
        negativeWeight  |
        Float  |
        Weight of the negative assessment point.  |
        negativeScore  |
        Float  |
        Score of the negative assessment point.  |
        Parameter  |
        Type  |
        Description  |
        id  |
        String  |
        Sensitive word ID.  |
        name  |
        String  |
        Content of sensitive words.  |
        score  |
        Integer  |
        Sensitive word score.  |
        beginTime  |
        Long  |
        Start timestamp of the training content, accurate to seconds.  |
        endTime  |
        Long  |
        End timestamp of the training content, accurate to seconds.  |
        speechId  |
        Integer  |
        Training content ID.  |
Request Example
    "language": "zh_CN",
    "channelType": "exam",
    "speeches": "{\"examID\":\"${examID}\",\"speech\":\"${speech}\"}",
    "callTime": "${callTime}"
 Response Example
    "examResponse": {
        "examId": "TQ5",
        "score": 80.0,
        "answerRules": [
                "positiveAnswer": "Positive answer of No.18",
                "positiveWeight": 0.5,
                "positiveScore": 40.0,
                "negativeAnswer": null,
                "negativeWeight": 0.0,
                "negativeScore": 0.0
        "sensitiveWordRules": {
            "sensitiveWordRuleMatch": []
    "qiResponse": null
 Input Parameter Configuration Example
In the manually entered message body, enter a request example. The ${Variable name} variable is automatically displayed on the Input Parameter tab page.
Output Parameter Configuration Example
        Parameter  |
        Path  |
        Description  |
        score  |
        $.examResponse.score  |
        Exam score (excluding sensitive words). This parameter is returned during training scoring.  |
