/chatbot/rest/tuc/v1/nlp/detectEntity
Function
Entity recognition interface.
Input Parameters
        Parameter  |
        Type  |
        Mandatory (Yes/No)  |
        Description  |
        language  |
        String  |
        Yes  |
        Language. The options are as follows: zh_CN en_US ar es_ES pt_BR th_TH multi fr_FR  |
        sentence  |
        String  |
        Yes  |
        Recognition text.  |
Output Parameters
        Parameter  |
        Type  |
        Description  |
        entityMsgV2List  |
        List <EntityMsgV2>  |
        For details, see Table 1.  |
        count  |
        Integer  |
        Number of identified entities.  |
        Parameter  |
        Type  |
        Description  |
        FORMAT_RAW  |
        String  |
        Format.  |
        id  |
        Integer  |
        ID.  |
        citation  |
        String  |
        Reference name of an entity, for example, reference name of an address in a system entity (@system.address).  |
        type  |
        Integer  |
        Entity type.
        userEntity  |
        Boolean  |
        Whether the entity is a user entity.  |
        envEntity  |
        Boolean  |
        Whether the entity is an environment entity.  |
        beginIndex  |
        Integer  |
        Start sequence number in the input statement when the entity value is identified.  |
        endIndex  |
        Integer  |
        End sequence number in the input statement when the entity value is identified.  |
        values  |
        Map <String, String>  |
        Identified entity value pair. The value is in Entity type:Entity value format. Example: "@system.address": "Yuelu District, Changsha City, Hunan Province"  |
        formats  |
        List <String>  |
        List of reference formats that identify the entity. For example, in the value ["raw","province"], "raw" indicates the original value, and "province" indicates the province.  |
        synonyms  |
        List <String>  |
        Synonym.  |
Request Example
    "language": "${language}",
    "sentence": "${sentence}"
