Help Center/
      Customer Engagement Center/
        User Guide/
        Tenant Administrator Guide/
        Robot Management and Configuration Guide/
        Configuring an Intelligent Robot/
        Other Operations/
      Adding Data Tables
        Updated on 2025-01-23 GMT+08:00
Adding Data Tables
If customized data is required in a flow, you can add a customized data table and then add or import data to it. When editing a flow, you can use the Data Table diagram element to use data in a customized data table.
- Choose .
 - Choose  and click
. The Adding a Data Table dialog box is displayed. - Enter basic data table information.
    Figure 1 Adding a Data Table
    - Table Name: Enter a globally unique table name. The value can contain a maximum of 64 characters.
 - Table ID: Enter a globally unique table ID. The value can contain a maximum of 32 characters, including letters, digits, and underscores (_), and cannot start with a digit.
 - Description: Enter a table description. The value can contain a maximum of 255 characters.
 - Click
. The Adding a Table Field dialog box is displayed. - Enter basic table field information.
    Figure 2 Adding a Table Field
    - Field ID: Enter a unique field ID in the data table. The value can contain a maximum of 32 characters, including letters, digits, and underscores (_), and cannot start with a digit.
 - Field Name: Enter a unique field name in the data table. The value can contain a maximum of 64 characters.
 - Field Type: Select a field type. The options are Character, Integer, and LogTime.
 - Field Length: Enter a field length. The total length of all fields cannot exceed 10,000 characters. This parameter needs to be set only when Field Type is set to Character or Integer.
 - Default Value
- When Field Type is set to Character, enter a maximum of 255 characters as the default value.
 - When Field Type is set to Integer, enter an integer as the default value.
 - When Field Type is set to LogTime, select a date as the default value.
 - Description: Enter a field description. The value can contain a maximum of 255 characters.
 - Encrypted: Determine whether a field needs to be encrypted for storage.
 - In the Adding a Table Field dialog box, click Confirm to save the table field.
 - In the Adding a Data Table dialog box, click Confirm to save the data table.
 - Click Data to add table data.
    Figure 3 Data
     - Click Add to add data.
    Figure 4 Add Data
     - In the Add Data dialog box, click Save to save the data.
 - Click Edit to edit data.
    Figure 5 Edit Data
     - Click Delete. In the Confirm deletion dialog box, click
. The data is deleted successfully.
   Parent topic: Other Operations
