Managing Variables
Adding a Global Variable
- Choose .
 - Choose  and click
. - Set Variable Name and Data Type, as shown in the following figure.
 - Select an encryption type and click Confirm.
     For security purposes, set Encryption Type to Encrypted for storage and decrypted upon retrieval or Encrypted for storage and retrieval if the variable contains personal data, such as the customer ID card number.
Modifying a Built-in Variable
- Choose .
 - Choose and click the Built-in Variable tab.
 - Click Edit in the Actions column of one of the following built-in variables and change the default value based on site requirements.
Table 1 Built-in variables Variable Name
Data Type
Value Range
Default Value
language
Use this variable to set the language of the tenant.
Character
- Chinese
 - English
 - Spanish
 - Arabic
 - Thai
 - Portuguese
 - French
Chinese
timezone
Use this variable to set the offset of the time zone in which the tenant resides.
Floating-point number
–12 to 12
None
channeltype
Use this variable to set the channel of the tenant.
Character
default
default
responsestyle
Use this variable to set the style of the tenant.
Character
default
default
ttsSpeed
Use this variable to set the TTS speech speed of the tenant.
Integer
–500 to 500
0
ttsVolume
Use this variable to set the TTS volume of the tenant.
Integer
0 to 100
50
ttsPitch
Use this variable to set the TTS fundamental frequency of the tenant.
Integer
–500 to 500
0
voiceName
Use this variable to set the TTS speaker of the tenant.
Character
- Graceful
 - Mature
 - Soft
 - Sweet
 - Natural
Graceful
 - After the modification is complete, click
