Updated on 2025-11-07 GMT+08:00
Chinese Version Installation
  1. Double-click the installation package to run the installation program
  2. Click Install. (You may need to enter the computer user password for authorization.)
  3. Complete the installation.
  • After the installation is complete, you can run DefaultWebMode.sh in the installation directory to switch the program to the service mode (where the program window is hidden and the program icon appears in the task bar after the program is started).
  • If you run the sudo dpkg -i com.huawei.openeye*.deb command to install the software, when the message "launch mode without UI: yes/no ?" is displayed, you can enter yes to select the service mode.
