Creating Co-browsing Rules
A tenant administrator can configure rules. When a customer shares a page with an agent during co-browsing, some sensitive information on the customer page is shielded based on the configured co-browsing rules to protect customer information.
Context
When creating co-browsing rules, you need to use the CSS selector syntax. You are advised to familiarize yourself with the syntax in advance.
The Co-browsing feature has been enabled for the tenant.
- Sign in to the AICC as a tenant administrator and choose .
- Click New.
- Set Rule name. The value must:
- Contain only letters, digits, and underscores (_).
- Contain a maximum of 128 characters.
- Set Page Match Type as required.
- Generic Matching: The rule takes effect for all pages that are browsed collaboratively under the tenant.
For example, all password text boxes and the Submit button are shielded.
- Match by URL path: The pattern of the URL accessed by the browser can be configured. The rule is the same as that of AntPathMatcher of Spring.
?: matches a single character.
*: matches zero or more characters.
**: matches zero or more paths (multi-level paths separated by slashes).
Example: https://localhost:63343/**
- Match by page ID: Generic Matching and Match by URL path cannot exactly match a page. In this case, Match by page ID can be used.
The page ID matching mode requires customized development of the page URL. The cobrowse_page_id parameter is passed in the page URL for exact matching.
- (Optional) Set Page Match Config. This step is required when Page Match Type is set to Match by URL path or Match by page ID.
The value can contain a maximum of 1024 characters.
- Set Page Element Selector. The selected page elements are shielded during co-browsing. The value must:
- Be in a format that meets the syntax requirements of the CSS selector.
- Contain a maximum of 1024 characters.
Example: #input
- (Optional) Set Organization Unit. Select the OU created in Configuring OUs.
If no OU is configured or Unorganized is selected, the data can be used by all OUs.
- Click Save.
Follow-up Procedure
You can perform the following operations on the new rule:
- Edit
- Delete
