Help Center/ Customer Engagement Center/ User Guide/ Tenant Administrator Guide/ Making Intelligent Outbound Calls/ Preparations for Creating Outbound Call Tasks/ Enabling Task-level ACD Detection
Updated on 2025-11-07 GMT+08:00
- When an outbound call is made, the ACD detection function can be used to:
- Check the status of the called party before the outbound call is connected. For example, check whether the called party is busy or whether the called number does not exist.
- Check whether the answering party is a person or a device such as a fax, a modem, or an automatic answering machine after the outbound call is connected.
- The ACD detection function supports three control modes: system-level, tenant-level, and task-level.
- You have enabled the corresponding system-level parameter by performing the following operations:
- Log in to the WAS as the system administrator, choose , and enable the ACD detection function.
- You have enabled the corresponding tenant parameter by performing the following operations:
- Log in to the WAS as the system administrator, choose , select the corresponding tenant space, click
, and enable the ACD detection function on the Basic Info tab page.
- You have enabled the corresponding system-level parameter of the AICC by performing the following operations:
- Sign in to the AICC as the system administrator, choose , and set Whether to enable ACD detection capability to Yes.
- You have enabled the corresponding tenant parameter of the AICC by performing the following operations:
- Sign in to the AICC as the system administrator, choose , and set ACD detection on mode to Enable detection on the Virtual Call Center tab page of the corresponding tenant.
- Sign in to the AICC as a tenant administrator and choose .
- Enter a task name and click
to query the corresponding task.
The ACD detection function is not supported for manual outbound calls, manual assignment outbound calls, and previewed outbound calls.
- Click Edit to enable the task-level ACD detection function.
Parent topic: Preparations for Creating Outbound Call Tasks
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
