Updated on 2025-11-07 GMT+08:00
Managing Special Dates
Special dates are specified in automatic outbound call tasks. For example, if a call center expects the agents to make outbound calls on workdays at a time different from that on weekends and public holidays, set weekends and public holidays to special dates which can be selected when you create automatic outbound call tasks.
Some operations under the current menu are controlled by separate permissions. If related operation permissions are not configured, the corresponding operations are not supported. For details about the operation permissions that can be configured separately, see Table 1.
Context
You can set special dates in any of the following ways:
  • Specify one or more days in a week, usually weekends or workdays.
  • Specify a date or time period. Generally, usually holidays or workdays temporarily adjusted.
  • Specify one or more days in a year, usually public holidays.
Business Scenario
In a call center, Saturday and Sunday are special days, and no agent needs to be on duty.
  1. Sign in to the AICC as a tenant administrator and choose Configuration Center > Call Config > Holidays.
    Figure 1 Holidays page
  2. Click New to create a special date.
    Figure 2 New Special Date page
  3. Set Task Type to By Week, and select Saturday and Sunday. The following table describes the parameters on the page.
    Table 1 Parameters on the Create Special Date page (By Week)
    Special Date Name
    Enter a special date name.
    Organization Unit
    The options are as follows:
    • Tenant administrator: All OUs under the current tenant are available.
    • Agent:
      1. If the tenant parameter Has the tenant enabled inter-organization data isolation enforcement is set to Yes, OUs that can be accessed by agents are available.
      2. If the tenant parameter Has the tenant enabled inter-organization data isolation enforcement is set to No, all OUs are available.
      3. Accessible OUs selected on the Configuration Center > Employee Center > Employee > Add Employee page are available.
        Contact the tenant administrator to set tenant parameters on the Configuration Center > System Management > Tenant Parameter page.
    Task Type
    Set this parameter to By Week.
    Select Date
    Select dates as required, for example, select Saturday and Sunday.
    Table 2 Parameters on the Create Special Date page (By Date)
    Special Date Name
    Organization Unit
    • Agent:
    Task Type
    Set this parameter to By Date.
    Select Date
    Set Start Date and End Date.
    The end date must be later than or equal to the start date.
    Table 3 Parameters on the Create Special Date page (Repeat By Year)
    Special Date Name
    Organization Unit
    • Agent:
    Task Type
    Set this parameter to Repeat By Year.
    Select Date
  4. Click OK.
