Updated on 2025-11-07 GMT+08:00
Case Closure Reason
A tenant space administrator can set case closure reasons.
  1. Sign in to the AICC as a tenant space administrator and choose Configuration Center > Case Configuration 2.0 > Case Configuration > Case Close Reason.
    Figure 1 Case Close Reason page
  2. Click and create a case closure reason by referring to Table 1.
    Figure 2 Create Case Close Reason
    Table 1 Parameters for creating a case closure reason
    Element/Component
    Remarks
    Organization
    • After the tenant parameter Has the tenant enabled inter-organization data isolation enforcement is set to Yes, use either of the following methods to configure the OU data scope based on site requirements:
      • For accounts without the View All Organization Data permission under System Public Permissions configured:
        • If the Viewing and Editing Home Organization Data and View Lower-Level Organization Data permissions under System Public Permissions are not configured, only the OUs specified by Accessable Organizations configured on the Employee Info or Organization Unit page can be selected.
          If accessible OUs are configured on the Employee Info or Organization Unit page, the accessible OU configuration permission on the Employee Info page is used.
        • If the Viewing and Editing Home Organization Data permission under System Public Permissions is configured, the OU (excluding sub-OUs) to which the current business account belongs can be viewed.
        • If the View Lower-Level Organization Data permission under System Public Permissions is configured, the sub-OUs of the OU to which the current business account belongs can be viewed.
      • For accounts with the View All Organization Data permission under System Public Permissions configured, all OUs can be selected.
      • The number of OUs that can be selected is specified by the value of the system-level parameter Maximum number of OU organizational unit queries on the Configuration Center > System Management > System Parameter > System parameters > Unified Public Configuration > Common page.
    • After the tenant parameter is set to No, all OUs can be selected.
    Close Reason
    Closure reason.
    • The value contains a maximum of 128 characters.
    • The value must be unique.
    Upper-level reason
    Reasons are displayed by layer, for example, Resolved > Design change > Insufficient budget.
    A maximum of five layers are supported.
    Description.
  3. Click .
  4. In the case closure reason list, click corresponding to the new closure reason to change the status to .
  5. Choose Case 2.0 > Case Workbench and click a case to be closed in the case list. On the case details page that is displayed, click . In the dialog box that is displayed, select a closure reason.
    Figure 3 Selecting a case closure reason
  6. Choose Case 2.0 > Case Workbench, select cases to be closed in the case list, and click . In the dialog box that is displayed, select a closure reason.
    Figure 4 Selecting a case closure reason when the Batch Closure function is used
    Cases to be closed in batches must belong to the same OU.
