Help Center/
Customer Engagement Center/
User Guide/
Tenant Administrator Guide/
Configuring Multimedia Channels/
Configuring the Instagram Channel/
Configuring Instagram Information
Updated on 2025-01-23 GMT+08:00
None
- Sign up for an Instagram personal account.
Sign-up address: https://www.instagram.com/
- Sign up for a Facebook personal account.
Sign-up address: https://www.facebook.com/
- Log in to Meta for Developers and apply for a Meta for Developers account.
- Use the personal account to log in to Meta for Developers at https://developers.facebook.com/.
- Click Get Started in the upper right corner.
- Create a Meta for Developers account as prompted.
- Verify the account. If the account has been verified during registration, skip this step.
- Check the email information.
- Select Developer and click Complete Registration.
- On the app creation page that is displayed, click Create App.
- Select Business and click Next.
- Create an app.
- On the page that is displayed, select Messenger and Webhooks.
- In the navigation pane, choose Messenger > Settings, and click Create new Page.
- Create a public home page. Set the name and category of the public home page and click Create Page.
You can skip the step for binding the public home page to WhatsApp.
- After the home page is created, click the avatar in the upper right corner to switch to the home page.
- Select
- Click Linked Accounts and bind the home page to your Instagram account.
- Return to the Messenger page, choose Instagram settings, and click Add or remove Pages.
Click Continue as ***.
- Select the home page to be added and click Continue.
- Subscribe to Webhooks.
- Generate a token.
- Click Generate token on the added home page.
- Record the generated token, which will be used in subsequent operations. Then, click Done.
Parent topic: Configuring the Instagram Channel
