Help Center/
Customer Engagement Center/
User Guide/
Inspector Guide/
Processing Manual Post-Event Inspections/
Viewing Inspection Results
Updated on 2025-01-23 GMT+08:00
- Choose .
- Set search criteria and click Search to obtain the search result. Click Reset to clear the existing search criteria.
Figure 1 Task Result
- Click Adding An Export Task to export the inspection result.
- Click Details. On the Manual Inspection page, view the score details and summary for the current inspection record.
Parent topic: Processing Manual Post-Event Inspections
