Response (Expired and Not Recommended)
This diagram element is used with the Ringing diagram element. When Ringing is used with the Transfer diagram element and Transfer Configuration is set to Transfer to Skill Queue, you need to configure the Robot Reply diagram element to provide the agent answering capability.
Diagram Element
Parameter Description
The following figure shows the parameters of the Robot Reply diagram element.
The parameters are described as follows:
- Node Name: Enter a diagram element name. The value can be customized.
Typical Application Scenario
