Information Query
This diagram element is used to query the status of the current customer in the queue. When all agents are busy, the system plays the waiting tone to the customer through the IVR.
Currently, you can query the queuing position, the number of all online agents in a skill queue, and the estimated time required for accessing an agent.
This diagram element is used to query details about agents in configured skill queues.
This diagram element is used to query whether the customer is in the special list.
Queuing information of only voice and video businesses can be queried. Queuing information of multimedia businesses cannot be queried.
Diagram Element
Parameter Description
- Querying queuing information
- Query Type: information type that can be queried using this diagram element. Currently, queuing information can be queried.
The queuing information is queried using an IVR flow when a call is transferred to a skill queue.
- Query result
- Queue Position: position of a customer in the current skill queue, that is, the number of queuing customers in front of the customer. You can use a global variable (GLOBAL.*) or flow variable (FLOW.*) to save the value for subsequent operations.
- Number of online agents: total number of online agents in the skill queue to which a customer belongs. You can use a global variable (GLOBAL.*) or flow variable (FLOW.*) to save the value for subsequent operations.
- Estimated waiting time: estimated duration for connecting a call to an agent during queuing. This parameter is affected by Queue Position and Number of online agents. You can use a global variable (GLOBAL.*) or flow variable (FLOW.*) to save the value for subsequent operations. The estimated waiting time depends on the queue model. The result may be inaccurate. Therefore, use this parameter properly.
- Skill Queue Identifier: ID of the skill queue to which a user is queuing. You can use a global variable (GLOBAL.*) or flow variable (FLOW.*) to save the value for subsequent operations.
- Querying queue information
- Query Type
Queue information: Query queue information before a call is transferred to a skill queue.
- Request Parameter
Skill Queue: skill queue to which a call is transferred.
Skill queue ID: ID of the skill queue to which a call is transferred. You can assign a value by using a variable.
- Query result
- Number of queues: number of customers in the current skill queue before a call is transferred to another skill queue. You can use a global variable (GLOBAL.*) or flow variable (FLOW.*) to save the value for subsequent operations.
- Number of online agents: total number of online agents in the skill queue to which a call is transferred. You can use a global variable (GLOBAL.*) or flow variable (FLOW.*) to save the value for subsequent operations.
- Number of idle agents: total number of online and idle agents in the skill queue to which a call is transferred. You can use a global variable (GLOBAL.*) or flow variable (FLOW.*) to save the value for subsequent operations.
- Estimated waiting time: estimated time for connecting a call to an agent after the call is transferred to a skill queue. You can use a global variable (GLOBAL.*) or flow variable (FLOW.*) to save the value for subsequent operations. The estimated waiting time depends on the queue model. The result may be inaccurate. Therefore, use this parameter properly.
- Query Type
- Querying the queue name
- Query Type
Queue name: The name of a skill queue to which an agent belongs can be queried based on the agent ID.
The scenario is to query the skill queue name based on the agent ID before the call is transferred to the skill queue to which the agent belongs.
- Request Parameter
Agent ID: agent ID. Flow variables or constants are supported.
- Query result
Queue name: name of the voice skill queue with the highest weight in the skill queue to which the agent ID belongs. Use the global variable (GLOBAL.*) or flow variable (FLOW.*) for subsequent operations.
You can choose to configure the skill queue weight.
- Query Type
- Querying special list information
- Query Type
Special list information: Currently, the system can check whether a customer is in the special list based on the customer number. The next process varies depending on the special list query result.
The special list refers to the blocklist.
- Query result
Identifier in the special list: whether the calling number exists in the special list. Use the global variable (GLOBAL.*) or flow variable (FLOW.*) for subsequent operations.
The values of Identifier in the special list are as follows: 0 indicates that the calling number does not exist in the special list, and 1 indicates that the calling number exists in the special list.
- Query Type
Condition Branch Description
Condition Branch |
Description |
Usage |
SYSERROR_INNER |
ODFS internal error |
Triggered when an unknown error occurs in the ODFS. If no option is selected, the flow goes to the exception handling flow. |
Using the Diagram Element
The Information query diagram element can be used to query information such as the queuing status and special list information of the current customer.
Click the diagram element or drag it to the canvas, and set parameters based on the parameter description.
Typical Application Scenario
A customer makes a call to the AICC, and the call is routed to a skill queue. When all agents in the skill queue are busy, if Queuing Method is set to IVR and an intelligent IVR flow is selected for the skill queue, the intelligent IVR flow can use this diagram element to obtain the current queuing status of the customer and play the waiting tone to the customer. Therefore, the customer can determine whether to continue waiting based on the queuing status.
Scenario 1: Query queuing information.
- Orchestrate a flow. In the flow, use the Information query diagram element to query data, including the number of online agents, queuing position, and estimated waiting time.
- Create three flow variables to receive the query result.
Figure 1 Flow variables to be added
- Configuring an IVR voice. Use the created flow variables in the IVR voice content.
Figure 2 Added IVR voice
- Configure a resource template.
Figure 3 Page for configuring a resource template
- Create a flow, use the Information query diagram element to assign values to the three flow variables, and use the Robot Reply diagram element to select the configured resource template.
Figure 4 Flow orchestration example
- Configure an intelligent robot and set Dialog Type to IVR flow.
- Choose , click Edit corresponding to the skill queue, and set Queuing Method to IVR added in 1.
Figure 5 Page for editing skill queue parameters
- Choose and add a called route. Set Skill Queue to the skill queue added in 2.
- Log in to the OpenEye using a softphone number to simulate a customer, and dial the access code added in 3 on the Called Party page. If the current queue information is heard, the configuration is successful.
Scenario 2: Query queue information.
- Create four flow variables to receive the query result.
Figure 6 Flow variables to be added
- When using the diagram element to create a flow, if you want to transfer a call to a skill queue in the flow, you can query the information about the skill queue and then determine whether to transfer the call to the skill queue. The subsequent businesses are determined based on site requirements.
- Choose and add a called route. Set the IVR to the added intelligent IVR.
- Log in to the OpenEye using a softphone number to simulate a customer, and dial the access code added on the Called Party page. If the current queue information is heard, the configuration is successful.
Scenario 3: Query special list information.
- Create a flow variable to receive the query result.
- Configure a flow by referring to the following figure. When the flow runs to the special list information query node, the flow invokes an interface to query special list information, obtains the query result, and enters different flows based on the query result.
Figure 8 Flow orchestration example
- Log in to the OpenEye using a softphone number to simulate a customer, and dial the access code added on the Called Party page. If the current special list information is heard, the configuration is successful.
