Help Center/
      Customer Engagement Center/
        User Guide/
        Inspector Guide/
        Performing Agent Monitoring and Inspections/
        Monitoring Configuration/
      Configuring Monitoring and Inspection Relationships
        Updated on 2025-01-23 GMT+08:00
Inspectors and agents have been configured for the tenant.
- Sign in to the AICC as a tenant administrator and choose .
 - Configure an agent group.
- Click the Traffic Group tab.
      Figure 1 Traffic Group
       - Click
 to create an agent group.
      Figure 2 Creating an agent group
      - User Group Name: The value cannot contain special characters and must be unique.
Click Save.
 - Select the new agent group, click Add in the Configure Role Info area on the right, and add agents to the agent group.
      Figure 3 Adding agents to an agent group
      Agents of all roles can be selected.
Click OK.
 - (Optional) You can perform the following operations on an agent group and its members.
- Hover the pointer over the agent group and click
 to delete the agent group and its members. - Click
 to edit basic information about the agent group. - Search for configured agents in the agent group based on the agent ID, name, and business account.
 - Click Delete corresponding to a configured agent to delete the agent from the agent group.
 - Select multiple configured agents and click Delete to delete the agents in batches.
 - Configure an inspector group.
- Click the Quality Inspection Group tab.
      Figure 4 Quality Inspection Group
       - Click
 to create an inspector group.
      Figure 5 Creating an inspector group
Click Save.
 - Select the new inspector group, click Add in the Configure Role Info area, and add agents to the inspector group.
      Figure 6 Adding agents to an inspector group
      Only agents of the Quality checker role can be selected.
Click OK.
 - Click the Inspection Relationships tab, click Add, and configure monitoring and inspection relationships.
      Figure 7 Adding agent groups to be inspected
      Click OK.
 - (Optional) You can perform the following operations on an inspector group, its members, and inspection relationships.
- Hover the pointer over the inspector group and click
 to delete the inspector group, its members, and inspection relationships configured for the group. - Click
 to edit basic information about the inspector group. - Search for configured agents in the inspector group based on the agent ID, name, and business account.
 - Click Delete corresponding to a configured agent to delete the agent from the inspector group.
 - Search for configured inspection relationships by agent group name.
 - Click Delete corresponding to a configured inspection relationship to delete it.
 - Select multiple configured inspection relationships and click Delete to delete the inspection relationships in batches.
 - Search for inspection relationships.
- Click the Query Inspection Relationships tab.
 - Enter an inspector group or inspected group and click
 to search for configured inspection relationships.
      Figure 8 Query Inspection Relationships
       - Click More and set more search criteria, including Inspector Name, Inspector ID, Inspected Party Name, and Inspected Party ID, to search for inspection relationships.
   Parent topic: Monitoring Configuration
