Updated on 2025-11-07 GMT+08:00
Checking Flows
You can check the usage of composite diagram elements, business interfaces, stored procedures, gray rules, resource templates, global variables, and flows variables in all flows.
Some operations under the current menu are controlled by separate permissions. If related operation permissions are not configured, the corresponding operations are not supported. For details about the operation permissions that can be configured separately, see Table 1.
  1. Choose Configuration Center > Chatbot Management > Flow Configuration.
  2. Choose Flow > Flow Check and click to obtain the latest statistics.
    Figure 1 Flow Check page
  3. Click the Never Used sector or legend in the pie chart to view details about unused resources.
