Setting Intelligent Engine Parameters
Configuration personnel can modify system parameters and intention parameters of the current tenant as required. However, the modification of these parameters will affect services. Therefore, ensure that you understand the parameter functions before performing operations.
- Choose . The Intelligent IVR Management page is displayed.
- Choose System Management > Intelligent Engine Parameter. On the System Parameters tab page, click Edit in the row that contains the parameter to be modified, select a variable value, and click Save.
- On the Intention Parameters page, select the language to be modified, modify the parameters to be modified, and click Save.
