- Getting Started
User Guide
- CEC Operation Guide
Tenant Administrator Guide
- Tenant Space
- Configuring the Employee Center
Enabling Manual Services
- Voice and Video Services
Agent Workbench
- Configuring Call Reasons
- Configuring Rest Reasons
- Configuring Contact Record Data Items
- Configuring the Voice Notification Function
- Configuring the One-Click Bidirectional Call Function
- Configuring Screen Pop-ups
- Configuring Pages
- Configuring Dynamic Data Tables
- Querying Table Data
- Managing the Multimedia Library
- Configuring Identity Authentication Processes
Other Configurations
- Configuring the Fault Prompt Tone
- Configuring Satisfaction Surveys
- Configuring the Customized Tone (Agent Ringback Tone)
- Configuring Page Message Notifications
- Configuring Voice Silent Agents
- Managing Messages
- Viewing Contact Records
- Viewing Bidirectional Call Records
- Configuring the Online Chat Service Time
- Viewing Skill Queue Adjustment Records
- Viewing Identity Authentication Records
- Managing Documents
- Managing Harassment Records
- Configuring Service Guidance
- Configuring SmartCare Integration Information
- Configuring a Mobile Agent
Configuring Multimedia Channels
- Configuring the WeChat Channel
- Configuring the Web Channel
- Configuring the X (Twitter) Channel
- Configuring AICC Information
- Configuring the 5G RCS Channel
- Configuring the Email Channel
- Configuring the LINE Channel
- Configuring the WhatsApp Channel
- Configuring the SMS Channel
- Configuring the Instagram Channel
- Configuring the Telegram Channel
FAQ
- How Do I Set the Click-to-Dial Called Route?
- How Do I Enable the Last Agent Mode?
- How Do I Set Session End Due to No Customer Reply?
- How Do I Set Session Transfer Due to No Agent Reply?
- How Do I Set Session Transfer?
- How Do I Set the Third-Party Authentication Key?
- How Do I Enable Offline Messages?
- How Do I Enable Message Push?
- How Do I Enable the Auto Reply and Non-Workday Reply Functions?
- How Do I Enable Connection to the Intelligent Robot?
- How Do I Enable Connection to the Robot Assistant?
- Creating an App Using a Facebook Developer Account
- How Do I Set Automatic Email Reply?
Robot Management and Configuration Guide
- Getting Started
Configuring an Intelligent Robot
- Overview
- Configuring an Appointment Chatbot (Task-oriented Robot)
- Adding a Q&A-oriented Robot
Other Operations
- Managing Variables
- Maintaining Stored Procedures
- Creating Work Calendar Templates
- Adding Data Tables
- Adding Domains
- Adding Entities
- Adding Sensitive Words
- Adding Knowledge Gray Rules
- Managing Models
- Managing Robot Test Cases
- Reviewing a Historical Message
- Processing a Question Clustering Task
- Setting Intelligent Engine Parameters
- Managing the Call History
- Viewing Flow Analysis
- Checking Flows
- Adding Gray Rules
- Configuring 2D Virtual Humans
- Configuring the SmartCare Intelligent Robot
Reference
Diagram Elements
- Start
- Robot Reply
- Conversation Analysis
- Subflow
- Call Ending
- Switching Between Voice and Video Calls
- Voice Playback
- Voice Playback and Digit Collection
- Language Selection
- Semantic Recognition
- Menu Configuration
- Call Transfer
- Error Count Clearance
- Branch Judgment
- Logic Loop
- Variable Assignment
- Rule Validation V2
- Time Selection
- Interface Invocation
- Data Table
- Stored Procedure
- Information Query
- User Level
- Message Leaving
- SMS
- Satisfaction Configuration
- Key Recognition (Expired and Not Recommended)
- Rule Verification (Expired and Not Recommended)
- Date Processing (Expired and Not Recommended)
- SMS Sending (Expired and Not Recommended)
- JSON Data Invoking (Expired and Not Recommended)
- Composite
- Avatar Reply
- Connection Lines Between Diagram Elements
- Parameters
TUC Interfaces
- /chatbot/rest/tuc/v1/nlp/detectRegularEntity
- /chatbot/rest/tuc/v1/nlp/identify
- /chatbot/rest/tuc/v1/recommendFaq
- /chatbot/rest/tuc/v1/qualityInspection/qiOnline/recognize
- /chatbot/rest/tuc/v1/nlp/feedback
- /chatbot/rest/tuc/v1/nlp/textClassify
- /chatbot/rest/tuc/v1/nlp/detectEntity
- Built-in Functions
Diagram Elements
- Why Do I Need to Configure Stop Words?
- Why Are Some Intentions Matched Despite Low Matching Rates?
- Why TTS Cannot Identify the Date Format?
- How Do I Configure the Scenario Where Multiple Slots Are Filled Repeatedly?
- How Do I Resolve the Problem of Infinite Loop During Interaction Between the IVR and ODFS?
- How Do I Configure the Number of Voice Recognition Errors in a Flow?
- How Do I Configure an Entity That Matches Any Character String?
- What Causes Incorrect ASR?
- How Do I Transfer the Disconnection Reason Code to the Specified Business Interface?
- How Do I Configure the Language Recognition Interface?
- How Do I Configure Dynamic Flow Variables?
- How Do I Use a Rule Corpus?
- How Do I Assign Values to and Use Lists and Objects?
- How Do I Parse Call-associated Data?
- How Do I Press a Key to Collect Digits or Return to the Upper-Level Menu When the Play Voice & Collect Digit Diagram Element Does Not Support the Asterisk (*) Key?
Operator: Configuring a Common IVR
- Introduction to the IVR Flow
- Managing Voice and Video Resources
- Configuring a Common IVR
- Configuring Robot Tracking
- Configuring a Called Route
- Configuring a Flow Track
- Configuring IVR Recording
- Querying Flow Transfer Records
- Typical Configuration Example
Diagram Elements
- Start
- Subflow
- Call Ending
- Voice Playback
- Call Transfer
- Branch Judgment
- Logic Loop
- Data Table
- Stored Procedure
- Time Selection
- Information Query
- User Level
- Message Leaving
- SMS
- Survey
- Call Ending (Expired and Not Recommended)
- Condition Judgment (Expired and Not Recommended)
- Ringing (Expired and Not Recommended)
- Response (Expired and Not Recommended)
- User Level (Expired and Not Recommended)
- Time Selection (Expired and Not Recommended)
- Assignment (Expired and Not Recommended)
- Transfer (Expired and Not Recommended)
- Interface Invocation (Expired and Not Recommended)
- Configuring the Preconfiguration Intelligent Flows
- Large Language Model Service Zone
- Small Language Model Zone
- IVR Journey Analysis
- Monitoring Outbound Call Risks
- Managing Cases
Managing Inspections
- Overview on Inspection Management
- Typical Scenario: Configuring Manual Inspection Tasks
- Managing Manual Inspections
- Typical Scenario: Configuring AI Inspection Tasks
- Managing AI Inspections (Self-Developed)
- Managing the Notification Center
- Managing the Customer Center
Making Intelligent Outbound Calls
- Overview of Outbound Call Tasks
Preparations for Creating Outbound Call Tasks
- Managing Special Dates
- Managing Blocklisted Outbound Numbers
- Defining Business Results
- Defining Outbound Call Data Attributes
- Defining Outbound Call Results
- Creating Outbound Call Templates
- Managing the Special List
- Configuring an Outbound Call File Server
- Importing Mapping Rules
- Managing Task Groups
Managing Outbound Call Tasks
- Creating Common IVR Outbound Call Tasks or Intelligent Robot Outbound Call Tasks
- Creating Predicted Outbound Call Tasks
- Creating Previewed Outbound Call Tasks
- Creating Preempted Outbound Call Tasks
- Creating Fixed Outbound Call Tasks
- Creating Manual Outbound Call Tasks
- Configuring an Outbound Call Task
- Managing Outbound Call Tasks in Batches
- Managing Multimedia Marketing
- Managing Outbound Call Task Reports
- Managing Surveys
- Managing Intelligent Training
- Configuring the Knowledge Base
Configuring Public Resources
- Modifying Policy Information
- Viewing Interconnection Parameters
- Configuring Parameters
- Adding Customer Numbers to the Special List
- Configuring the Channel Special List
- Managing a Certificate
- Configuring Email Special List Rules
- Configuring SMS Special List Rules
- Configuring Resource Dump Tasks
- Managing Menus
- Managing Email Signatures
- Configuring Message Flow Control Rules
- Configuring UC Integration
- Managing Emails
- Configuring External Numbers
- Querying Operation Logs
- Querying Sign-in Logs
- Managing Business Fault Bypass
- Co-browsing
- Social Media Operations
- Performance Management
Agent Guide(AICC)
- Introducing Agent Workbenches
- Switching the Agent Status
- Allowing Browser Pop-up Notifications
- Handling Voice Businesses
- Handling Video Businesses
- Handling Multimedia Chat Businesses
Performing Other Agent Operations
- Configuring the Personal Center
- Querying Historical Contacts
- Viewing Inbound Call Information
- Setting the Handled Number
- Setting Call Reasons
- Setting the Online Chat Service Time
- Configuring Personalized Common Phrases
- Sending Notifications
- Performing Identity Authentication
- Viewing Customer Information
- Creating Harassment Records
- Editing Customer Information
- Querying Sign-In Records
- Performing Screen Recording for Agents
- SmartCare Fault Demarcation
- Intelligent Case Filling
- Creating a Case by One Click
- Searching for Satisfaction Statistics
- Managing Inspection Results
- Typical Scenarios
- Viewing Training Tasks
Intelligent Outbound Call Tasks
Agent Outbound Call Task
- Introduction to the Outbound Call Task of an Agent
- Manually Making an Outbound Call
- Viewing and Executing a Previewed Outbound Call
- Viewing a Predicted Outbound Call
- Viewing a Preempted Outbound Call
- Creating a Reserved Outbound Call Task
- Adding a Customer Number to the Blocklist
- Changing an Outbound Number
- Viewing Outbound Call Results
- Reserved Manual or Automatic Outbound Call
- OpenEye Help Document
- Implementing Intelligent Case Filling
Inspector Guide
- Processing Manual Post-Event Inspections
- AI Inspection
Performing Agent Monitoring and Inspections
- Monitoring Configuration
- Monitoring Management
Report Query
- VDN Traffic Report
- VDN Traffic Report by Access Code
- IVR Traffic Report
- IVR Traffic Report by Access Code
- Skill Queue Traffic Report
- Skill Queue Traffic Report by Access Code
- Traffic Summary Report
- Agent Traffic Report
- Agent Outbound Call Report
- Agent Operation Report
- Abandoned Call in Ringing Report
- Interval-based VDN Traffic Report
- IVR Outbound Call Report
- System Performance Report
- Agent Timesheet Report
- Price Details
Developer Guide
Development Overview
- Development Map
Development Solutions
- Multimedia Channel Access Solution
- Self-Service (IVR) Integration Solution
- Voice and Video Agent Integration Solution
- Multimedia Agent Integration Solution
- Mobile Agent Integration Solution
- Screen Pop-up Integration Solution
- Intelligence Solution
- Operations Monitoring and Report Integration Solution
- Automatic Outbound Call Integration Solution
- CDR Download and Recording Backhaul Integration Solution
- Development Preparations
- Contact Us
- User Access-VoIP Voice and Video Access
User Access-Web Lightweight Client Integration (JS)
- Lightweight Web Chat Control Integration (Token Mode)
- Lightweight Web Chat Control Integration (Authorization Mode)
User Access--Web Client Access (RESTful)
- Overview
- Machine-Machine Interface, AK/SK-based Authentication Interface
- Third-party Request Authentication
- Query Queue Information
- Proactively Poll Information Sent by Agents
- Submit Customer Satisfaction Evaluation Results
- Send Message
- Send Files by Customer
- Receive Document by Customer
- Associate Common Phrases
- Create Click-to-dial Call
- Get Click-to-dial Event
- Check Whether Support Click-to-dial
- Release Click-to-dial Call
- Submit Offline Messages by Customer
- Create an Anonymous Call
- Submit Customer Satisfaction with Robots
Agent Integration-Agent Lightweight Connection Block Integration (JS)
- Overview
- Integration Principles
- Integration Procedure
- Preparations
- Integration Development
- (Optional) Developing Other Functions
- Test and Verification
- Agent Integration--CC-Gateway Development Guide
Agent Integration-OpenEye H5 Softphone Interface Integration
- Change History
- OpenEye H5 Softphone Interface Overview
- OpenEye Installation Guide
- Development Guide to H5 Softphone Integration on the Agent Side
- Voice Call Interfaces
Voice and Video Call Interface Extension
- Voice and Video Calls
Device Management
- getMediaDevices (Obtaining the Device List)
- setMicIndex (Setting the Microphone)
- mediaGetMicIndex (Querying the Microphone in Use)
- setSpeakIndex (Setting the Speaker)
- mediaGetSpeakIndex (Querying the Speaker in Use)
- setMicVol (Setting the Microphone Volume)
- getMicVol (Querying the Current Microphone Volume)
- setSpkVol (Setting the Speaker Volume)
- getSpkVol (Querying the Current Speaker Volume)
- setVideoWindowParam (Setting the Position, Width, and Height of the Video Window)
- setVideoLayoutMode (Setting the Video Window Layout Mode)
- setVideoDisplayMode (Setting the Image Cropping Mode in the Video Window)
- openCamera (Turning on the Camera)
- closeCamera (Turning off the Camera)
- Screen Sharing
- Screenshot
- Screen Recording
- Error Codes
Operation Management - Agent Workbench Integration with Third-Party Web Pages
- Overview
- Scenario 1: Integration by Using a URL (in GET Parameter Transfer Mode)
- Scenario 2: Integration by Using a URL (in POST Parameter Transfer Mode)
Scenario 3: Integration by Using a URL (in Page JavaScript Invocation Mode)
- Overview
- Development Procedure
- Preparation
- Importing AICC.Support.js
- Developing the Function of Registering Listening Events
- Developing the Function of Removing Listening Events
- Developing the Function of Making One-Click Outbound Calls
- Developing the Function of Obtaining the Identity Authentication Result
- Development Example
- Post-development Configuration
Appendix - Process Description
- Overall Working Process
- Process of Registering a Listening Event (addHandler)
- Process of Removing a Listening Event (removeHandler)
- Process of Executing a One-Click Outbound Call (clickToOutbound)
- Process of Executing the Handling Method of a Registered Event
- Process of Executing the One-Click Outbound Call Method
- Process of Obtaining the Identity Authentication Result
- Scenario 4: Integration by Invoking an Enterprise API
- Scenario 5: Integration by Recording Information to the CEC
API Reference
- Interface Overview
- Glossary
- Change History
- Interface Authentication Modes
Call Center Configuration Interface Reference
Agent Management
- Creating a Single Agent Account (agentAccount/create)
- Deleting a Specified Agent Account (agentAccount/delete)
- Modifying Information About an Agent Account (agentAccount/update)
- Querying Agent Account Information (agentAccount/query)
- Binding an Agent to a Skill Queue (addSkillsToAgent)
- Unbinding an Agent from a Skill Queue (releaseAgentBySkillId)
- Querying Agent Information by Skill Queue ID (queryAgentInfoBySkillId)
- Changing the SIP Phone Number Login Password of an Agent (updateSipPhonePassword)
- Querying Softphone Information of All Agents, Excluding Business Accounts (querySysInfo)
- Querying Softphone Information of All Agents, Including Business Accounts (queryAgentInfo)
- Querying the Account Sign-in Result (queryAgentLoginParams)
- Querying Agent Information by Sign-in Account (queryAgentInfoByAccount)
- Deleting Data by Customer Number (cleancustpersonaldata)
Skill Queue Management
- Creating a Skill Queue (createSkill)
- Deleting a Skill Queue (deleteSkill)
- Modifying a Skill Queue (modifySkill)
- Querying Skill Queues (querySkills)
- Obtaining the Total Number of Users in a Configured Skill Queue
- Obtaining the Number of Users in a Skill Queue to Which an Agent Has Signed In
- Obtaining the Skill Queue Information of the Home VDN of an Agent
- Obtaining the Total Number of Users in a Specified Skill Queue
- Querying the Statistics About a Set of Skill Queues
- Querying the IVR Information of the VDN to Which an Agent Belongs
- Querying Information About Agents That Have Signed In to a Skill Queue
- Querying the Details About a Specified Agent
- Querying the Details About All Online Agents That Have Signed In to a Skill Queue
Number Management
- Querying Access Codes (queryAccessCodeList)
- Creating a Binding Relationship Between an Access Code, Skill Queue, and IVR (createCalledRoute)
- Deleting the Binding Relationships Between Access Codes, Skill Queues, and IVR Flows (deleteCalledRoute)
- Modifying a Binding Relationship Between an Access Code, Skill Queue, and IVR (modifyCalledRoute)
- Querying the Binding Relationships Between Access Codes, Skill Queues, and IVR Flows (queryCalledRoute)
- Querying the Home Area of a Number (getPhoneNoRegionInfo)
IVR Flow Management
- Querying All IVR Flows of a Specified Tenant Space (queryIVRFlowList)
- Querying Satisfaction Survey Information (querySatisfactionConfig)
- Querying Satisfaction Survey Results (satisfaction /query)
- Uploading IVR Voice Files (importVoiceFile/upload)
- Uploading a TTS Template for Voice Notifications (createVoiceTemplate)
Agent Management
Agent Workbench Interface Reference
Agent Control
Agent Operation Interfaces: onlineagent
- Signing In
- Forcibly Signing In
- Maintaining the Heartbeat by an Agent
- Sending Notes
- Querying Configured Skill Queues
- Querying Configured Skill Queues of Specified Agents
- Setting Automatic Answering
- Resetting Skill Queues
- Setting Idle
- Setting Busy
- Canceling the Busy State
- Applying for Rest
- Canceling Rest
- Entering the Work State
- Quitting the Work State
- Changing the Password (Extended)
- Setting Whether to Enter the Idle State
- Signing Out
- Forcibly Signing Out
- Forcibly Signing Out with a Cause Code
- Getting Agent Status
- Setting Whether to Answer Inbound Calls
- Signing In to the Platform by an Agent
- Actively Requesting to Update the GUID When the Agent Page Is Refreshed
- Synchronizing the Agent Status and Call Information When the Agent Page Is Refreshed
- Obtaining Token Information
- Customizing Status by an Agent
- Querying Customized Status by an Agent
- Canceling Status Customization by an Agent
Call Control Interfaces: voicecall
- Making a Common Outbound Call
- Making a Previewed Outbound Call
- Answering a Call
- Making an Internal Call
- Asking for Internal Help
- Muting a Call
- Unmuting a Muted Call
- Holding a Call
- Holding a Call
- Unholding a Call
- Transferring a Call
- Canceling Transfer
- Performing Two-Stage Dialing (Extended)
- Making a Three-Party Call
- Disconnecting a Call of a Specified ID
- Dropping a Call
- Releasing a Connection of a Specified Number
- Controlling the Image Display Mode of a Three-Party Video Call
- Requesting a Specified Call
- Picking Up a Call for Other Agents
- Rejecting an Inbound Call
- Taking the Phone Off the Hook
- Rejecting a Call
- Passing Numbers in a Conference
- Answering Calls on a Mobile Phone (login)
- Exiting the Function of Answering Calls on a Mobile Phone (logout)
- Querying Whether a Specified Agent Answers Calls on a Mobile Phone (isOfflineAgent)
Call Data (calldata)
- Querying Call Information
- Querying Call-Associated Data
- Configuring Call-Associated Data (Extended)
- Querying the List of Held Calls
- Querying Call Information Before Answering a Call
- Querying Call Information by Call ID
- Querying Call IDs of a Specified Agent
- Querying the Number of Current Calls of an Agent
- Querying Current Call Statistics Information About an Agent
- Querying the Current Call Statistics of an Agent (Extended)
- Querying Information About Calls Waiting in a Specified Skill Queue
- Querying All Calls Placed on Hold by a Specified Agent
- Agent Event: agentevent
- Multimedia: mediaCall
Agent Conference: agentconf
- Applying for an Agent Conference
- Answering an Agent Conference Call
- Rejecting an Agent Conference Call
- Leaving an Agent Conference
- Releasing an Agent Conference
- Holding a Participant in a Conference
- Unholding a Participant in a Conference
- Applying for Extending a Conference
- Transferring the Chairperson Permission
- Inviting Participants in Batches
- Deleting Participants in Batches
- Modifying Participant Attributes
- Playing an Announcement in an Agent Conference
- Stopping Conference Announcement Playing
- Playing an Announcement in an Agent Conference Channel
- Stopping Announcement Playing in an Agent Conference Channel
- Changing the Number of Conference Participants
- Querying Conference Information in Batches
- Querying an Ongoing Conference ID in the VDN
Agent Bidirectional Calls
- Creating a Bidirectional Call (V1.0.0) (createCall)
- Creating a Bidirectional Call (V3.0.0) (createCall)
- Querying Call History Records (queryCallDetailRecord)
- Querying Call Status (queryCallState)
- Obtaining the Recording File URL (getRecordingAddress)
- Querying Allocated Softphone Numbers (V1.0.0) (queryPhone)
- Querying Allocated Softphone Numbers (V2.0.0) (queryPhone)
- Obtaining the Information About the Destination Device of a Call (getCalledInfo)
- Creating a Voice Outbound Call (V1.0.0) (createVoiceNotification)
- Creating a Voice Outbound Call (V2.0.0) (createVoiceNotification)
- Querying Contact Records (queryUserContactLimit)
- Querying Call Information (queryCallInfoByCallId)
- Sending an ITA Bidirectional Call Result Notification (statusnotify)
- Callback Interface
Voice Recognition Result Subscription Interfaces
- Subscription
- Subscription Modification
- Unsubscription
- Handshake
- Handshake (Extended)
- Recognition Result Notification
Error Code Definition
- Error Codes Returned by the CC-Gateway
- Common Voice Recognition Result Subscription Interface Error Codes
- Common Error Codes Returned by the CTI Platform
- VDN Configuration Interface Error Codes Returned by the CTI Platform
- System Configuration Interface Error Codes Returned by the CTI Platform
- Error Code Returned by UAP
- Role Permission Bit Description
- App Personal Settings
Appendix
Events
- Events Related to Agent State
Audio and Video Call Event
- Entering the Talking State
- Customer Ringing
- Holding Success
- Entering Three-Party Conversation Successfully
- Making an Outgoing Call Unsuccessfully
- Outbound Call Failure Cause Detected
- Making an Internal Call Unsuccessfully
- No Answer from an Agent for a Long Time
- Agent Exiting a Call
- User Exiting a Call
- Automatically Answering a Call
- Notifying the Agent of an Inbound Call
- Connection Failure
- Consultation Failure
- Notifying the Transfer Success Result
- Returning from IVR
- Switching Between Audio and Video Calls
- Media Capability Check
- Inbound Call Notification
- Events Related to Outgoing Call
- Recording Events
- Events Related to Voice Playback by Quality Checks
- Events Related to Real-time Quality Control
- Events Related to Physical Phone
- Other Agent-Related Events
- Events Related to Multimedia
- Agent Conference Event
- Events Related to Disaster Recovery
- Phone Linkage Events
- Error Codes
- Agent Status
- Call Type
- Device Type
- Interface Parameters
Events
Agent Control
Telemarketing Outbound Call Interface Reference
Outbound Campaign Management Interfaces
- Adding an Outbound Campaign (V1)
- Adding an Outbound Campaign (V2)
- Modifying an Outbound Campaign (V1)
- Modifying an Outbound Campaign (V2)
- Deleting an Outbound Campaign
- Querying Details About an Outbound Campaign
- Querying All Outbound Campaigns
- Suspending an Outbound Campaign
- Resuming an Outbound Campaign
- Setting the Retry Policy of an Outbound Campaign
- Querying the Retry Policy of an Outbound Campaign
- Adding the Definition of an Outbound Call Business Result
- Querying the Definitions of Outbound Call Business Results
- Collecting Outbound Call Exception Statistics
- Adding Calling Numbers
- Deleting Calling Numbers
- Interfaces for Managing Outbound Campaign Holidays
- Interface for Outbound Blacklist Management
Outbound Call Data Interfaces
- Adding Outbound Numbers
- Adding Outbound Numbers (V2)
- Deleting an Outbound Number
- Adding Number Types
- Querying Number Types
- Querying Outbound Numbers
- Collecting Outbound Call Statistics on the Current Day
- Importing an Outbound Call Data File from the Server
- Querying Outbound Call Data File Import Results
- Outbound Result Interface
- Outbound Callback
- Business Result Writeback
- File Server Management Interfaces
- Outbound Call External Result Definition Interfaces
- Querying Interface Invocation Records
- Survey Interface Reference
- iKBS Interface Reference
Chatbot Management Interface Reference
- Overview
- Domain Query Interface
- Dialog ID Binding Interfaces
- Flow Query Interface
- Dialog Interfaces
- Dialog Interfaces (V2)
- Interaction Record Query Interface
- Session Record Query Interface
FAQ Configuration Interface
- FAQ Group Query Interface
- FAQ Group Creation Interface
- FAQ Group Modification Interface
- FAQ Group Deletion Interface
- FAQ Group Status Change Interface
- Q&A Query Interface
- Q&A Creation Interface
- FAQ Modification Interface
- Q&A Deletion Interface
- Specific FAQ Group Test Interface
- FAQ Group Test and Activation Interface
- Intention List Query Interface
- Dedicated Interfaces for Silent Agents
- Interface for Pushing Packet Capture Recording Request Results
- Spelling Check Interface
- Specifications of the Interface for Connecting the ODFS to a Third-Party Robot System
- Statistics Report
- Querying the Offline Analysis of Outbound Call Failure Causes
- Intelligent Case Interface
- Interface for Querying the Recordings of Calls Transferred to a Third Party
- Semantic Recognition Interface
- GTS RPA Integration Interfaces
- Interface for Generating TTS Voices Based on Texts
- Offline Conversion Callback Interface
- Health Check Interface
Web Client Access Interface Reference
- Performing Third-Party Request Authentication (applyToken)
- Querying Queuing Information (queryQueueInfo)
- Proactively Polling Messages Sent by Agents (poll)
- Submitting the Customer Satisfaction Evaluation Result (saveSatisfaction)
- Sending a Message (send)
- Sending a File by a Customer (uploadFileStream)
- Receiving a File by a Customer (downloadFileStream)
- Associating Common Phrases Based on the Customer Input (queryPhraseByKeyword)
- Checking Whether the Current Tenant Space Supports the Click-to-dial Function (checkClickToCallSupport)
- Creating a Click-to-Dial Call (createClickToCall)
- Obtaining a Click-to-Dial Event (getClickToCallEvents)
- Releasing a Click-to-Dial Call (dropClickToCall)
- Creating an Anonymous Call (createcall)
- Submitting a Message by a Customer (doLeaveMessage)
- Submitting the Chatbot Satisfaction Evaluation Result (feedbacksatisfaction)
- Querying Historical Messages (queryHistoryChatMessage)
- Discarding an Email (chat_dropMail)
- Sending an MT WhatsApp Message (sendWhatsappMessage)
- Querying Information About the Current Chat on the Online Chat Workbench (getUserInfoBycallId)
- Querying the Satisfaction Survey Configuration (getSatisfactionSurveyMode)
Inspection, Monitoring, and Statistics Collection Interface Reference
Real-time Inspection: qualitycontrol
- Inserting
- Listening
- Intercepting
- Canceling Listening and Inserting
- Indicating an Agent in Busy State Forcibly
- Indicating an Agent in Idle State Forcibly
- Releasing a Call Forcibly
- Adjusting the Skill Queue of a Specified Agent
- Switching Between Listening and Inserting
- Forcing an Agent to Rest
- Requesting for Whispering
- Stopping Whispering
- Switching Among Whispering, Listening, and Barging
Intelligent Quality Check
scoresetting
- POST /CCSQM/rest/ccisqm/v1/appraisescore/createAppraiseScore
- POST /CCSQM/rest/ccisqm/v1/appraisescore/applyAppraiseScore
- POST /CCSQM/rest/ccisqm/v1/appraisescore/removeAppraiseScore
- POST /CCSQM/rest/ccisqm/v1/appraisescore/queryAppraiseScore
- POST /CCSQM/rest/ccisqm/v1/appraisescore/modifyAppraiseScore
sentencemanagement
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/createSentenceCategory
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/moveSentenceToCategory
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/deleteSentence
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/querySentence
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/querySentenceByCategoryId
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/updateSentence
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/updateSentenceCategory
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/deleteSentenceCategory
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/querySentenceCategory
sensitiveWordManage
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/deleteSensitiveWord
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/querySensitiveWordList
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/deleteSensitiveCategory
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/updateSensitiveWord
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/querySensitiveCategoryList
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/querySensitiveWordsByCategoryId
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/createSensitiveCategory
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/moveSensitiveWordToCategory
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/createSensitiveWord
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/updateSensitiveCategory
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/querySensitiveWordDetail
- conversationspecific
- SemanticKeywordTraining
- conversationflow
- conversationrules
interposalrules
- POST /CCSQM/rest/ccisqm/v1/interposal-rules/getInterposalRuleById
- POST /CCSQM/rest/ccisqm/v1/interposal-rules/queryInterposalRules
- POST /CCSQM/rest/ccisqm/v1/interposal-rules/deleteInterposalRule
- POST /CCSQM/rest/ccisqm/v1/interposal-rules/addInterposalRule
- POST /CCSQM/rest/ccisqm/v1/interposal-rules/updateInterposalRule
- Common Parameter Structure
- silencerule
- speedrule
scenariomanage
- POST /CCSQM/rest/ccisqm/v1/scenariomanage/deleteScenario
- POST /CCSQM/rest/ccisqm/v1/scenariomanage/updateScenarioStatus
- POST /CCSQM/rest/ccisqm/v1/scenariomanage/createScenario
- POST /CCSQM/rest/ccisqm/v1/scenariomanage/queryScenario
- POST /CCSQM/rest/ccisqm/v1/scenariomanage/queryAllScenario
- qualitycheckmanage
regularQualityTask
- POST /CCSQM/rest/ccisqm/v1/regularqualitytask/addQualityTask
- POST /CCSQM/rest/ccisqm/v1/regularqualitytask/beginQualityTask
- POST /CCSQM/rest/ccisqm/v1/regularqualitytask/updateQualityTask
- POST /CCSQM/rest/ccisqm/v1/regularqualitytask/deleteQualityTask
- POST /CCSQM/rest/ccisqm/v1/regularqualitytask/queryQualityTask
- POST /CCSQM/rest/ccisqm/v1/regularqualitytask/stopQualityTask
qualitytask
- POST /CCSQM/rest/ccisqm/v1/qualitytask/deleteQualityTask
- POST /CCSQM/rest/ccisqm/v1/qualitytask/updateQualityTask
- POST /CCSQM/rest/ccisqm/v1/qualitytask/terminateQualityTask
- POST /CCSQM/rest/ccisqm/v1/qualitytask/takeEffectQualityTask
- POST /CCSQM/rest/ccisqm/v1/qualitytask/queryQualityTask
- POST /CCSQM/rest/ccisqm/v1/qualitytask/appointQualityTask
- POST /CCSQM/rest/ccisqm/v1/qualitytask/createQualityTask
- qualitytaskdetail
qualityitem
- POST /CCSQM/rest/ccisqm/v1/qualityitem/reassginQualityTask
- POST /CCSQM/rest/ccisqm/v1/qualityitem/modifyQualityItemResult
- POST /CCSQM/rest/ccisqm/v1/qualityitem/appealItem
- POST /CCSQM/rest/ccisqm/v1/qualityitem/queryQualityItem
- POST /CCSQM/rest/ccisqm/v1/qualityitem/queryQualityItemDetail
- POST /CCSQM/rest/ccisqm/v1/qualityitem/queryQualityItemResult
- POST /CCSQM/rest/ccisqm/v1/qualityitem/queryQualityHistory
- asrtrans
scoresetting
Monitoring and Statistics Collection
Real-Time Data Query
Real-Time Interfaces for VDNs
- Querying Information About System Access Codes in a Specified VDN
- Querying Agent Rest Information in a Specified VDN
- Querying Agent Phone Numbers in a Specified VDN
- Querying Information About All Agents in a Specified VDN
- Querying Information About the Current Status of All Agents in a Specified VDN
- Querying Information About Static Configurations of All Agents in a Specified VDN
- Querying IVR Status Details in a Specified VDN
- Querying Information About IVR Flow Access Codes in a Specified VDN
- Querying Information about Each Skill Queue in a Specified VDN
- Querying All Rest Reason Codes in a Specific VDN
- Querying Information About Calls of a Specified Access Code
- Querying Call Information in a Specified VDN
- (V2) Querying Call Information in a Specified VDN
- Querying the Call track Data in a Specific VDN
- Querying Static Configuration Information About All Agents in a Specified VDN (Not Supported by CTI 3.6)
- Querying Information About All Agents in a Specified VDN (Not Supported by CTI 3.6)
- Obtaining Real-Time Monitoring Indicators by VDN
Real-Time Interfaces for Skill Queues
- Querying Signed-in Agents in Skill Queues in Batches
- Querying Extended Information About Skill Queues in Batches
- Querying Call Statistics of Skill Queues in the Current 5 Minutes in Batches
- Querying Information About Status of a Specified Skill Queue
- Querying Information About Skill Queue Configurations in Batches
- Querying Statistics Details of Skill Queues in Batches
- Querying All Calls Queuing in a Skill Queue in Batches
- Querying the Number of Calls that Each Queue Answers from Other Queues in Batches When Calls are Queuing in Multiple Skill Queues
- Querying the Number of Agents in Each State in a Skill Group
- Querying Details About Signed-in Agents in a Skill Queue
- Querying Service Quality for Skill Queues in Batches
- Obtaining Real-Time Monitoring Indicators by Skill Queue
Real-Time Interfaces for Agents
- Querying Skill Queues to Which Agents Sign In in Batches
- Querying Agent Information in Batches
- Querying the Current Call ID of a Specified Agent
- Querying Call Information About All Agents in Batches
- Querying Private Calls of a Specified Agent
- Querying the Number of Agents in the Agent State in batches
- Querying Details of a Specified Agent
- Checking Whether an Agent Is Processing a Call
- Querying System Status by Agent
- Obtaining Real-Time Monitoring Indicators by Agent
- Obtaining Agent Operation Details
- Querying Agent Information by Agent Status in Pagination Mode
- Real-Time Interfaces for Call Details
Historical Data Query
- Obtaining Historical Monitoring Indicators by VDN
- Querying Information About Missed Calls in a Specified VDN
- Obtaining Historical IVR Monitoring Indicators
- Obtaining Historical Monitoring Indicators by Skill
- Obtaining Historical Monitoring Indicators by Agent
- Obtaining Historical Monitoring Indicators in a Specified Time Range by Skill
- Obtaining Historical Monitoring Indicators in a Specified Month Range by Skill
- Obtaining Historical Monitoring Indicators in a Specified Time Range by Agent
- Obtaining Historical Monitoring Indicators in Specified Month by Agent
- Collecting Statistics on Result Sets in Daily Settlement Table for Inbound Calls
- Collecting Statistics on Result Sets in Daily Settlement Table for Outbound Calls
Configuration Data Query
- Querying Information about All VDNs in a Specified Call Center
- Querying Information About All Agents by VDN ID
- Obtaining All Called Routes in a VDN
- Querying Information About All Agents by Tenant Space ID
- Querying Skill Groups in a Specified VDN
- Querying Information About All Tenants Accessible to an Access User
Inspection Relationship Maintenance Interfaces
- Querying a User Group Member
- Deleting Members from a Group in Batches
- Adding Members to a Group in Batches
- Querying All User Groups
- Adding a User Group
- Deleting a User Group
- Updating User Group Information
- Setting Inspection Relationships
- Deleting Configured Inspection Relationships
- Adding an Agent to a User Group
- Updating Agent Names
- Querying Outbound Call Task Lists
Interfaces for Querying System Indicators
- Querying UAP Performance Information
- Querying Key Information About Control Blocks
- Querying the Registration Status of a Terminal
- Interface for Querying UAP Performance Indicator Statistics
- Interface for Querying UAP Terminal Statistics
- Interface for Querying CTI System Indicators
- Querying the Time of the CTI Platform Server
- Querying the Current License Usage in the System
- Checking Cluster Health Status
Appendix
- Indicator Code Reference
- Error Code Reference
- CTI Platform Agent Status Code Reference
- Description of Call Media Types
- Description of Call Submedia Types
- Description of Call Types
- Description of Agent Types
- Call Features
- Reasons for Leaving the Device of the Call
- Cause Code
- Device Types
- Agent Operation Types
- Interfaces of Earlier Versions (Versions Earlier Than 8.13.0)
Recording and CDR Interface Reference
- Recording
CDR Download and Recording Playback and Download
Data Access Interface
- Obtaining a Recording Download and Playback URL
- Generating CDRs and Recording Indexes
- Downloading CDRs and Recording Indexes
- Downloading a Recording File
- Downloading a Recording File (Extended)
- Generating Indexes of Agent Operation Details
- Downloading Indexes of Agent Operation Details
- Requesting to Play Back a Recording File
- Playing Back a Recording File
- Downloading an Intelligent IVR Recording File
- Downloading IVR Voice Messages
- Downloading a Recording File as a Third Party
- Uploading a File as a Third Party
- Generating a File Hash Value as a Third Party
- Deleting an Uploaded File as a Third Party
- Index File Definition
- Reference Description
- Voice Notification Interface Reference
- OMA Interface Reference
- DataProcess Interface Reference
- Other Interfaces Reference
- FAQs
Show all
Configuring SMS Gateways
Context
If the user password for connecting to the SMS gateway is changed, you need to modify the configuration in the AICC as follows: Choose Configuration Center > Access Configuration > Gateway Configuration, click Edit in the Operation column corresponding to the gateway to be modified, click the Message protocol parameters tab, and enter the new login password.
- Sign in to the AICC as a tenant administrator and choose Configuration Center > Access Configuration > Gateway Configuration.
Figure 1 Gateway Configuration
- Click New. The Create Gateway page is displayed.
Figure 2 Create Gateway - Basic Information
- After basic information is configured, click Next. The Gateway Address Interconnection Configuration page is displayed.
- Basic Configuration: Parameters in this area are mandatory.
Figure 3 Gateway Address Interconnection Configuration - Basic Configuration
- SMG Address (mandatory): IP address of the SMS gateway, for example, 10.10.10.10.
- SMG Port (mandatory): Port number of the SMS gateway.
- Login Name: Account for logging in to the gateway. This parameter is optional when a gateway simulator is used.
- Login Password: Password for logging in to the gateway. This parameter is optional when a gateway simulator is used.
- Receiving And Sending Mode (mandatory): Whether the protocol device is used to send or receive SMS messages. The default value is Send and receive SMS messages. The options are as follows:
- Send and receive SMS messages: The protocol device is used to process messages received from the SMSC and send SMS messages.
- Receive SMS messages: The protocol device is used to process messages received from the SMSC.
- Send SMS Messages: The protocol device is used to send SMS messages.
- SMPP PDU Type (mandatory): Type of the SMPP PDU used for sending SMS messages. The default value is submit_sm. The options are as follows:
- submit_sm
- data_sm
- Sender ID Prefix (mandatory): Prefix of the number segment configured on the gateway for which SMS messages can be sent. The value can contain only letters and digits.
Sender ID prefix rule: In a number in the AICC, the part following the country code starts with a sender ID prefix. For example, if the number in the AICC is +86123xxxxxxxx, set this parameter to 123. Use semicolons (;) to separate multiple prefixes.
- Accepted Number Prefix (mandatory): Prefix of the number segment configured on the gateway for which SMS messages can be received. Value range: a number made up of digits
Accepted number prefix rule: In a customer number, the part following the country code starts with an accepted number prefix. For example, if the customer number is +86123xxxxxxxx, set this configuration item to 123. Use semicolons (;) to separate multiple prefixes.
- Default sender ID: default sender ID of the gateway. The value is the ID configured in Configuring SMS Message Sender IDs.
- ESME Connection Configuration: Parameters in this area are set by default and can be modified as required.
Figure 4 Gateway Address Interconnection Configuration - ESME Connection Configuration
- Client Port (mandatory): Number of an unoccupied port for the CC-Notification server. The port number is used to connect to the SMS gateway. If the client port needs to be specified for the SMS gateway, set this parameter. The value ranges from 0 to 65535.
The default value is 0, indicating that the CC-Notification randomly allocates a port number.
- Port for receiving upstream messages: Port number for receiving MO messages. The value ranges from 0 to 65535.
The default value is 0, indicating that the CC-Notification automatically allocates a port number.
- Heartbeat Interval(ms): Interval for sending heartbeat messages to the SMS gateway to maintain the persistent connection between the CC-Notification and SMS gateway. This parameter specifies the interval for sending heartbeat messages. The value is a number of 1 to 10 digits. The value must be greater than that of Transaction Timeout Interval(ms) and less than that of Receiving Timeout Interval(ms).
The default value is 30000, in milliseconds.
- Max Connection Times Upon No Heartbeat Response: Maximum number of consecutive heartbeat response failures. When this value is exceeded, the CC-Notification disconnects from the gateway. The value is a number of 0 to 5 digits.
The default value is 3.
- Resending Times: Maximum number of resending times. After the CC-Notification sends a heartbeat message, if the CC-Notification does not receive a heartbeat response within the transaction timeout interval, the CC-Notification waits for a period of time (specified by Resending Waiting Time(ms)) and then resends the heartbeat message. The value is a number of 0 to 10 digits.
The default value is 0.
- Resending Waiting Time(ms)
Interval for resending an SMS message after the CC-Notification receives an SMS message sending failure response from the SMS gateway. The value is a number of 0 to 10 digits.
- Receiving Timeout Interval(ms) (mandatory): Maximum duration for allowing no data transmission after an SMS device connects to the gateway. If the SMS device does not receive data from the peer device within this duration, automatic disconnection occurs. The value is a number of 1 to 10 digits. The value must be greater than those of Heartbeat Interval(ms) and Transaction Timeout Interval(ms). To prevent invalid connections, do not set this parameter to 0.
The default value is 180000.
- Max Error Packets Received: Number of error packets consecutively received by a device. If this value is reached, the link is faulty and will be disconnected. The value is a number of 0 to 10 digits.
The default value is 10.
- Sliding Window Size (mandatory): Instantaneous concurrent processing capability of the CC-Notification. This parameter is used to limit the number of messages sent by the CC-Notification, preventing errors that may occur on the SMSC due to great pressure. The value is a number of 2 to 5 digits.
The default value is 16. Generally, set this parameter to a multiple of 16.
- Transaction Timeout Interval(ms): Maximum duration for an SMS device to wait for a response from the peer device after sending a message. If the peer device does not respond within this duration, the SMS device does not wait any longer. The value is a number of 0 to 10 digits. The value must be less than those of Heartbeat Interval(ms) and Receiving Timeout Interval(ms).
The default value is 6000, in milliseconds.
- Max Message Length (bytes) (mandatory): Maximum message length specified by the protocol. The value is a number of 1 to 5 digits.
The default value is 2048, in bytes.
- Oversized SMS Splitting Mode (mandatory): Mode of splitting an SMS message when the message content length exceeds the value of Max Content Length (bytes). The options are as follows:
- disabled: A long SMS message is not sent, and an exception is reported on the CC-Notification.
- not split: The system directly sends an SMS message without checking whether it is too long.
- physical splitting: A long SMS message is segmented into multiple independent SMS messages based on the value of Max Content Length(bytes).
- ultra-long split: A long SMS message is split into several continuous SMS messages, that is, the system adds the combination control information to each sub-message. Terminals that support continuous SMS messages can combine the sub-messages into a complete SMS message.
The default value is disabled.
- Max Content Length(bytes) (mandatory): Maximum message content length specified by the protocol. A long SMS message is split based on the value of this parameter. The value is a number of 1 to 5 digits.
The default value is 140, in bytes.
- Min Sending Thread Pools (mandatory): Minimum number of threads that start in the thread pool when the protocol stack is used to send messages. The value is a number of 1 to 5 digits.
The default value is 20.
- Max Sending Thread Pools (mandatory): Maximum number of threads that start in the thread pool when the protocol stack is used to send messages. The value is a number of 1 to 5 digits.
The default value is 200.
- Sending Thread Pool Queue Length (mandatory): Length of the thread queue to be processed in the sending thread pool. The value is a number of 1 to 5 digits.
The default value is 2000.
- Min Receiving Thread Pools (mandatory): Minimum number of state report receiving threads. Set this parameter by referring to the settings of the sending thread pool, but the values can be different. The value is a number of 1 to 5 digits.
- Max Receiving Thread Pools (mandatory): Maximum number of state report receiving threads. The value is a number of 1 to 5 digits.
- Receiving Thread Pool Queue Length (mandatory): State report receiving thread queue length. The value is a number of 1 to 5 digits.
- Max Receiving Rate: Maximum rate at which messages are received using a protocol. The value can be empty or a positive integer. If the value is empty, the values of Max Sending Rate and Extra Traffic Processing Policy must also be empty.
- Max Sending Rate: Maximum rate at which messages are sent using a protocol. The value can be empty or a positive integer. If the value is empty, the values of Max Receiving Rate and Extra Traffic Processing Policy must also be empty.
- Extra Traffic Processing Policy: Policy for sending messages when the traffic exceeds the threshold. The value can be empty or a positive integer. If the value is empty, the values of Max Receiving Rate and Max Sending Rate must also be empty.
- Long Message Concatenation Mode (mandatory): Mode of combining long SMS messages. The options are GSM User Data Header and SMPP parameters.
The default value is GSM User Data Header.
- Message protocol parameters: Parameters in this area are set by default and can be modified as required.
Figure 5 Gateway Address Interconnection Configuration - Message protocol parameters
- ESME Type: External short message entity (ESME) type. The value can contain a maximum of 13 characters.
For details, see the description of the system_type field in the bind message of the SMPP protocol.
- ESME Address Type Code: Address type ID of the extended SMS message entity. The value is a positive integer less than 28.
For details, see the description of the addr_ton field in the bind message of the SMPP protocol.
- ESME Address Encoding Mode: Address encoding mode of the extended SMS message entity. The value is a number of 0 to 10 digits.
For details, see the description of the addr_npi field in the bind message of the SMPP protocol.
- ESME Address Range: Address encoding mode of the extended SMS message entity. The value can contain a maximum of 15 characters.
For details, see the description of the address_range field in the bind message of the SMPP protocol.
- Service Type: Type of the SMS application service specified by the gateway. The value can contain a maximum of 500 characters.
For details, see the description of the service_type field in the submit_sm/data_sm message of the SMPP protocol.
- Source Address Code Type (mandatory): Type of the code in the source address in SMPP SubmitMessage. The value is a number of 1 to 10 digits.
The default value is 0. For details, see the description of the source_addr_ton field in the submit_sm/data_sm message of the SMPP protocol.
- Source Address Code Scheme (mandatory): Scheme of the code in the source address in SMPP SubmitMessage. The value is a number of 1 to 10 digits.
The default value is 0. For details, see the description of the source_addr_npi field in the submit_sm/data_sm message of the SMPP protocol.
- Destination Address Code Type (mandatory): Type of the code in the destination address in SMPP SubmitMessage. The value is a number of 1 to 10 digits.
The default value is 0. For details, see the description of the dest_addr_ton field in the submit_sm/data_sm message of the SMPP protocol.
- Destination Address Code Scheme (mandatory): Scheme of the code in the destination address in SMPP SubmitMessage. The value is a number of 1 to 10 digits.
The default value is 0. For details, see the description of the dest_addr_npi field in the submit_sm/data_sm message of the SMPP protocol.
- Message Type (mandatory): Message type. The value is a number of 1 to 10 digits.
The default value is 0. For details, see the description of the esm_class field in the submit_sm/data_sm message of the SMPP protocol.
- Message Format (mandatory): SMS message encoding mode. The options are as follows:
- ASCII string: ASCII string in which one character occupies one byte
- binary information
- UCS2 encoding: ISO/IEC-10646 in which one character occupies two bytes
The default value is ASCII string.
- Protocol ID (mandatory): GSM protocol ID. The value is a number of 1 to 10 digits.
The default value is 0. For details, see the description of the data_coding field in the submit_sm message of the SMPP protocol.
- Return Status Confirmation Report (mandatory): State reports to be returned. The options are as follows:
- 0: No state report is received.
- 1: Success and failure state reports are returned.
- 2: Failure state reports are returned.
The default value is 2.
- Replacement Flag (mandatory): Whether to replace the existing SMS messages whose source addresses and destination addresses are the same. The options are Not replace and Replace.
The default value is Not replace.
- Default Message ID (mandatory): ID of a predefined SMS message. It is the index of a predefined SMS message created by the administrator of the message center. The value can contain a maximum of 500 characters.
The default value is 0. For details, see the description of the sm_default_msg_id field in the submit_sm message of the SMPP protocol.
- After gateway interconnection information is configured, click Save.
Follow-up Procedure
- Rebuild a gateway.
- Choose Configuration Center > System Management > Gateway Monitoring.
- Click Rebuilding.
- Disconnect a gateway that fails to be connected.
- Click Disconnected.
