On this page
Managing Inspection Categories
Updated on 2025-01-23 GMT+08:00
Context
You can define inspection category items from different dimensions to categorize inspection results. For example, you can define inspection category items from the rating level and business type dimensions. If you associate the defined inspection category with the inspection object type and inspection task, you can select the rating level and business type when rating the records related to an inspection task.
  1. Sign in to the AICC as a tenant administrator and choose Configuration Center > Quality Management > Inspection Category.
  2. Choose Add. In the Add Inspection Category dialog box, set category parameters.
    Figure 1 Add Inspection Category dialog box
    Set the following parameters:
    • Category Name: Customized name, which is mandatory. The value can contain a maximum of 1024 characters.
    • Description: Category description, which is optional.
    • Enable Multiple Choice: Whether a category supports selection of multiple category items. The options are Yes and No.
    • SN: Display sequence of a category on the manual inspection page.
  3. Click OK. The category configuration is saved, and the inspection category list page is displayed.
  4. Select the new inspection category and click Set Category Item. The Modify Inspection Category Item page is displayed.
    Figure 2 Modify Inspection Category Item page
  5. Click to add a category item and set category item parameters.
    • Name: Name of a category item.
    • Description: Description of a category item.
  6. Click Save. The category item configuration is complete.
Follow-up Procedure
Click Modify to modify an inspection category.
Click Delete to delete an inspection category that is no longer used.
