Help Center/ Customer Engagement Center/ User Guide/ Tenant Administrator Guide/ Configuring Multimedia Channels/ FAQ/ How Do I Set Session Transfer Due to No Agent Reply?
Updated on 2025-11-07 GMT+08:00
After Session Transfer Due to No Agent Reply is enabled, the timeout period for session transfer due to no agent reply and prompt message for agent reassignment can be customized.
- Click
to enable Session Transfer Due to No Agent Reply. - Set Agent Reply Timeout Period and Prompt for Agent Reassignment.
- Agent Reply Timeout Period: The value is an integer ranging from 1 to 1440 and must be less than or equal to that of Customer Reply Timeout Period.
- Prompt for Agent Reassignment: The value can contain a maximum of 256 characters.
You do not need to set this parameter for the email and SMS channels.
- Click The next step or Saved to complete the configuration.
Parent topic: FAQ
