Configuring the Email Channel
Updated on 2025-01-23 GMT+08:00
The AICC can use the SMTP and POP3 services to send and receive emails. Before configuring the email channel, ensure that the SMTP and POP3 services are enabled and the authorization password is correct.
For example, perform the following setting on the official website of the mailbox service and obtain the authentication password for configuring the connection to the mailbox client.
  1. (Optional) Obtain the certificate file of the email server and upload the certificate.
    Dedicated email service providers support the secure SMTP for email sending and POP3 for email receiving. Certificate authentication must be enabled for secure email sending and receiving protocols. Therefore, use the secure port provided by the email server provider for security purposes.
    Obtain the certificate and upload it by referring to Managing a Certificate. Set Cert Type to CER based on the file name extension.
  2. Sign in to the AICC as a tenant administrator, choose Configuration Center > Access Configuration > Gateway Configuration, and set parameters. The status of the configured gateways must be displayed as Connection succeeded on the Gateway Monitoring page.
    Set Protocol Type to POP3 for the email receiving gateway and SMTP for the email sending gateway.
  3. Choose Configuration Center > Access Configuration > Channel Configuration.
  4. Click Newly created. The Configure Channel page is displayed.
  5. Set channel information parameters.
    Table 1 Channel information parameters
    Channel Selection
    Select Email.
    Email receiving gateway
    Select a configured email receiving gateway. For details about how to configure a gateway, see Configuring Email Gateways.
    Email sending gateway
    Select a configured email sending gateway. For details about how to configure a gateway, see Configuring Email Gateways.
    Max. Recipients
    Maximum number of recipient email addresses.
    If this parameter is not set, the maximum number is determined by the tenant parameter Maximum number of recipients forwarded by email agents.
    The sum of the values of the three parameters in the Email Address Quantity Configuration area cannot exceed 100.
    Max. Cc Recipients
    Maximum number of Cc recipient email addresses.
    If this parameter is not set, the maximum number is determined by the tenant parameter Maximum number of Cc by email agents.
    Max. Bcc Recipients
    Maximum number of Bcc recipient email addresses.
    If this parameter is not set, the maximum number is determined by the tenant parameter Maximum number of Bcc by email agents.
    Reply with Personal Email
    This function is disabled by default. If the employee account is set to an email address, the employee account can be used to reply to emails after this function is enabled.
    Email Signature
    This function is disabled by default. For details about how to configure an email signature, see Managing Email Signatures.
  6. Set basic configuration parameters.
    Table 2 Basic configuration parameters
    Channel Name
    The channel name must be unique. The code can contain a maximum of 64 characters, including only letters, digits, and underscores (_), and can start only with a letter or an underscore (_).
    OU Configuration
    Select an OU created in Configuring OUs to assign it to channel resources.
    Skill Queue
    The options are all multimedia called routes of the current tenant space. For details about how to configure a called route, see Configuring Called Routes.
    Keyword for Transfer to Agent
    Keywords for switching from robot service to manual service. After a customer enters any of the keywords on the client, robot service is switched to manual service.
    If the intelligent robot is enabled, this parameter must be set.
    Agent Work Time
    • Workday: A maximum of four working time segments (from 00:00 to 24:00) can be configured. By default, a time segment is displayed. You can click New to add a time segment.
    • Non-workday: A maximum of four working time segments (from 00:00 to 24:00) can be configured. By default, a time segment is displayed. You can click New to add a time segment.
      Non-working days are set on the Configuration Center > Workbench Configuration > Service Time page.
    More
    Last Agent Mode
    For details, see How Do I Enable the Last Agent Mode?.
    Session End Due to No Customer Reply
    For details, see How Do I Set Session End Due to No Customer Reply?.
    Session Transfer Due to No Agent Reply
    For details, see How Do I Set Session Transfer Due to No Agent Reply?.
    Session Transfer
    For details, see How Do I Set Session Transfer?.
    Offline Messages
    For details, see How Do I Enable Offline Messages?.
    Automatic reply during working hours
    For details, see How Do I Enable the Auto Reply and Non-Workday Reply Functions?.
    Automatic reply during non working hours
  7. Set robot configuration parameters.
    Table 3 Robot configuration parameters
    Robot Configuration
    For details, see How Do I Enable Connection to the Intelligent Robot?.
  8. Click Save, and the configuration is complete.
    In addition, the system automatically creates a message route based on the selected email receiving gateway on the Configuration Center > Access Configuration > Notification Route page.
Follow-up Procedure
Export channel information.
  • All information under Basic Configuration and Robot Configuration can be exported. Passwords and keys cannot be exported.
  • A maximum of 100,000 channel records can be exported at a time, and a maximum of 2000 records are allowed in an exported file.
  • If no channel is selected, all channel information is exported by default.
  1. Return to the channel list.
  2. Select the new channel and click to export the channel information.
  3. Click and confirm that Status of the export task is Success.
  4. Click Download to obtain the exported channel information.
