Managing Harassment Records
A tenant administrator can review harassment records submitted by agents. After the records are approved, they are added to the special list. The tenant administrator and agents can view the review results.
- The common agent has the Harassment Record permission and the Harassment Record Review permission.
- Some operations under the current menu are controlled by separate permissions. If related operation permissions are not configured, the corresponding operations are not supported. For details about the operation permissions that can be configured separately, see Table 1.
- Sign in to the AICC as a tenant administrator and choose .
- Set search criteria as required to search for harassment record information.
Figure 1 Harassment Record page
Table 1 Key elements on the Harassment Record page Element
Type
Application time range
Calendar component
Application time range. Search criterion.
The time range cannot exceed seven days.
You can click
to delete the selected time range.Status
Drop-down list
Harassment record status. Search criterion.
- To be approved
- Approved
- Rejected
You can click
to delete the selected state.Special List Type
Drop-down list
Special list type. Search criterion.
- Black List
- Red List
Special List Level
Drop-down list
Special list level. Search criterion.
Operator
Text box
Operator business account. Search criterion.
You can click
to delete the entered operator.Subscriber number
Text box
Customer number. Search criterion.
Reset
Button
Reset search criteria.
Search
Button
Search for harassment records.
Button
Search for data based on search criteria again and refresh data on the page.
Subscriber number
Label
Customer number.
Special List Type
Label
Special list type.
- Black List
- Red List
Application Time
Label
Time when a harassment record is created.
Operator
Label
Business account of the agent who creates a harassment record.
Reason for Joining
Label
Reason for adding a customer number to the special list.
Operation
Button group
Operations that can be performed.
- Approval: Approve a record that has not been approved.
- View: View an approved or rejected record.
- Click Approval in the Operation column.
- Select Agree.
- Special List Level: Select a special list level.
- Effective Period: Set the time range when the special list record takes effect. The time range specified by Effective Period must be within the time range from the current time to January 19, 2038.
- Opinions: Enter the opinion on the harassment record. The value contains a maximum of 500 characters.
- Select Reject.
- Select Agree.
- Click Save.
After the application is approved, you can choose and click the Special List tab to view the new special list record.
After the approval is complete, you can choose to view the approval result. Approved harassment records are migrated to the history table every hour and cannot be queried on the GUI.
