Configuring the Fault Prompt Tone
A tenant administrator can customize the fault prompt tone, which is played to users when system agents are faulty.
You have configured a customized fault prompt tone by choosing and uploading a voice file whose Usage Scenario is error. The voice file can be used only after being approved by the system administrator.
After a tenant administrator enables the fault prompt tone function, the transfer-to-agent function of the tenant space becomes invalid. When a fault occurs, the configured fault prompt tone is played. However, the function of directly calling an agent is not affected by this feature.
For example, a transfer diagram element is configured in an IVR flow, and an agent who transfers a call to a skill queue is configured for the diagram element. When a customer accesses the IVR flow and chooses to transfer the call to a skill queue, the system plays the fault prompt tone. In addition, the function of transferring the call to an agent is invalid for all agents.
- Sign in to the AICC as a tenant administrator. Choose .
- Click
next to Feature to enter the editing mode. - Click
next to Breakdown Voice to enable the fault prompt tone function for the tenant. Figure 1 Breakdown Voice
- Select an approved prompt tone and click Save.
- The function is disabled by default. Each time the function is disabled, the message "Update tenant fault success." is displayed.
- The system provides a default prompt tone.
