Configuring a Page
- The system administrator has enabled the data customization function for the tenant space.
- A dynamic data table has been configured. For details, see Configuring a Dynamic Data Table.
- Sign in to the AICC as a tenant administrator and choose .
- Click . The creation page is displayed.
- Configure information about the customized page. Page Name: The value contains a maximum of 256 characters and must be unique.
- Click OK and save the customized page.
- The configuration of a customized page includes the page layout and page interface. Select the added customized page and configure it.
- Configure the page layout.
Figure 1 Page layout
Table 1 Page parameters Parameter
Page Layout
Layout Type
The options are as follows:
- Block layout
- Grid layout
Number of rows
- 2
- 3
- 4
SAVE
Click SAVE to save the current page layout information.
Page Interface
Internal interface
Configure the object list.
External interface
External interfaces are configured on the API Management page. Contact the system administrator.
Save
Click Save to save the interface parameter configuration on the current page.
Cancel
Click Cancel to cancel the interface parameter configuration on the current page.
- Configure the page interface.
- Internal interface
Figure 2 Internal interface
Figure 3 Selecting object attributes
Table 2 Internal interface parameters Parameter
Add Object
Click Add Object to add an object to the internal interface.
Object List
Object Name
Customize an object name.
Underlying Table Name
Select a released dynamic data table.
Selected Object Attributes
Select dynamic data table fields. You can select multiple fields.
Save
Click Save to save the configured object parameters.
Edit
Click Edit to modify the saved object parameters.
Delete
Click Delete to delete unnecessary objects.
Up
Click Up to edit the location of the object when adding multiple objects.
Down
Click Down to edit the location of the object when adding multiple objects.
- External interface
Figure 4 External interface
- Click Save. The customized page is configured.
- Click the name of configured page. The page information page is displayed. Under Page Status, click . In the confirmation dialog box that is displayed, click OK to release the customized page.
- Only released pages can be referenced by inbound call screen pop-ups. The release of pages referenced by inbound call screen pop-ups cannot be canceled.
- A maximum of five customized pages can be created. Delete unnecessary pages promptly.
Follow-up Procedure
You can perform the following operations on a configured page:
- Click to modify the selected page.
- Click to delete the selected page.
