Help Center/
Cognitive Engagement Center/
User Guide/
Tenant Administrator Guide/
Configuring Common IVR/
Diagram Elements/
Answer
Updated on 2023-09-20 GMT+08:00
Answer
Diagram Element
Parameter Description
The following figure shows the parameters of the Answer diagram element.
The parameters are described as follows:
- Element Name: Enter a diagram element name. The value can be customized.
Typical Application Scenarios
This diagram element is used together with the Ring diagram element.
Parent topic: Diagram Elements
