Updated on 2023-10-12 GMT+08:00
Configuring a Variable
  1. Sign in to the AICC as a tenant administrator and choose Configuration Center > Flow Configuration > Flow Management.
  2. Click . The Variable Management page is displayed.
  3. Click . The Add Variable page is displayed.
    Figure 1 Add Variable page
    • Name: The value cannot contain special characters.
    • Description: description of the variable.
    • Type: variable type, including integer and string. You can select a value from the drop-down list box.
    • Default Value: default value of the variable.
  4. After the configuration is complete, click OK to save the variable configuration.
  5. (Optional) You can perform the following operations on variables:
    • To edit a variable, click Edit in the Operation column. During the editing, only Description and Default Value can be modified.
    • To delete variables in batches, select the variables and click . To delete a variable, click Delete in the Operation column.
      Variables that have been used in a flow cannot be deleted.
