Allowing Clients to Access CDN Using IPv6
You can enable IPv6 to allow clients to access CDN PoPs using the IPv6 protocol. Most CDN PoPs support IPv6. After IPv6 is enabled, if a user uses IPv6 to access CDN but the optimal PoP does not support IPv6, the user can still use IPv4 to access the PoP.
IPv6 cannot be enabled for domain names with special configurations.
Precautions
If IPv6 is disabled for a domain name that previously had it enabled, IPv6 access traffic is still generated. This happens if the user's local DNS has resolution cache or if the user edits their hosts file to force the domain name to resolve to a PoP that supports IPv6.
- Log in to the CDN console.
- In the navigation pane, choose .
- In the domain list, click the target domain name. The Overview page is displayed.
- In the full configuration directory, click the More Service Configurations tab.
- Enable IPv6. Figure 1 IPv6
After IPv6 is enabled on the CDN console, if the origin server does not support IPv6 access, CDN pulls content using IPv4.
Helpful Links
Modifying the Full Domain Configuration to configure IPv6
