Overview
HTTPS ensures secure transmission through encryption and identity authentication. It is widely used in security-sensitive communications on the World Wide Web, such as online payment.
- You can configure a domain name certificate for CDN PoPs. Then clients can use HTTPS to access CDN PoPs. If you want CDN to use HTTPS for origin pull, configure an HTTPS certificate for your origin server.
- You can modify certificate settings of a domain name that is in the Enabled or Configuring state and is not locked or banned.
| Function | Description |
| An SCM agency is required for SCM certificate configuration, so that you can directly obtain the certificate content when configuring SCM certifications in CDN. | |
| Add a certificate on CDN PoPs to allow clients to access PoPs using HTTPS. | |
| Learn how to combine and upload certificates issued by different authorities. | |
| Convert certificates in other formats to the PEM format that CDN supports. | |
| Enable or disable Transport Layer Security (TLS) versions as required. | |
| Allow CDN to cache the status of online certificates in advance and return the status to browsers. Browsers do not need to query the status from certificate authorities (CAs), accelerating the verification. | |
| Configure force redirect to HTTP or HTTPS for requests from clients to CDN PoPs. | |
| Configure HSTS to force clients (such as browsers) to use HTTPS to access your server, improving access security. | |
| Understand the background and advantages of HTTP/2. | |
| Configure the QUIC protocol to improve transmission security, reduce transmission and connection latency, and prevent network congestion. | |
| Configure a client certificate to enforce mutual certificate authentication between clients and CDN PoPs, securing website communication. |
