HTTP Response Headers from PoPs to Clients (CORS)
Background
HTTP headers are part of an HTTP request or response message that defines the operating parameters of an HTTP transaction. HTTP headers in this function refer to the information that PoPs send to clients. After you set HTTP headers for a domain name, CDN includes them in responses to user requests for resources within that domain name.
Cross-origin resource sharing (CORS) allows cross-origin access. When website A accesses resources on website B, a cross-origin request is sent. If website B does not allow website A to access the resources, a cross-domain problem occurs. In this case, you can configure HTTP header settings and add custom headers in response messages returned to the requester to implement functions such as CORS.
Precautions
- Some headers cannot be set or deleted. For details, see Constraints.
- You can add up to 10 HTTP response header rules.
- HTTP header configuration is domain name-specific. When the configuration takes effect, the specified headers will be added to or removed from response messages for any resources under the entire domain. However, HTTP header configuration only affects the response behavior of the clients (browsers). They do not affect the cache behavior of CDN PoPs.
- If a CORS rule is configured on the CDN console, synchronize it to your origin server. If your origin server is an OBS bucket, configure CORS on OBS.
Supported Response Headers
Huawei Cloud CDN lets you customize the following different HTTP response headers:
- Content-Disposition
This header can start a download on clients and specify the name of the file to be downloaded.
When a server sends a file to a browser, as long as the file format is supported (for example, TXT or JPG), the file is opened using the browser by default. You can use this header to treat the file as an attachment and let users save it with a specific file name.
If you use an OBS bucket created after January 1, 2022 as the origin server and want to enable online preview, set Content-Disposition to inline. For details, see How Do I Preview OBS Objects in My Web Browser?
- Content-Language
This header specifies the preferred language or language combination of the browser. Content can be customized for different users.
- Access-Control-Allow-Origin
This header carries the domain names that are allowed for CORS after server authentication. For a simple CORS request, the browser determines whether to return the requested content to the client based on this header. For a preflight request, the browser determines whether to initiate an actual CORS request to the server based on this header.
To prevent cross-domain errors caused by browser cache, clear browser cache after configuring Access-Control-Allow-Origin.
- Timing-Allow-Origin
Timing-Allow-Origin is a non-standard HTTP response field. It is implemented by developers for enhanced control at the application layer. It introduces time locks and encrypted signatures to CORS, adding dynamic and time-based control. It is applicable to AI interfaces or API gateways that have high security requirements.
- Access-Control-Allow-Methods
This header carries the methods that are allowed for CORS after server authentication. For a simple CORS request, the browser determines whether to return the requested content to the client based on this header. For a preflight request, the browser determines whether to initiate an actual CORS request to the server based on this header.
- Access-Control-Max-Age
This header determines how long the results of CORS preflight requests allowed by the server can be cached. The browser determines the TTL for preflight request results based on this header. As long as the TTL has not expired, the browser can determine whether to initiate a CORS request to the server. Once this TTL expires, the browser needs to send another preflight request to the server.
- Access-Control-Expose-Headers
This header specifies the response headers that the browser can expose to the client. You can use this header to define the response headers visible to the client. The following response headers are visible to the client by default: Cache-Control, Content-Language, Content-Type, Expires, Last-Modified, and Pragma.
- Custom
If the preceding response headers cannot meet your needs, you can create response headers. A custom response header contains 1 to 100 characters, starting with a letter and consisting of letters, digits, and hyphens (-).
- Log in to the CDN console.
- In the navigation pane, choose .
- In the domain list, click the target domain name.
- Click the Advanced Settings tab.
- In the HTTP Headers area, click
. Figure 1 Configuring HTTP headers
- Click Add and select a response header operation from the drop-down list.
Response Header Operation
Set
- If the header already exists in the response, the header value you configure will overwrite the original one.
- If the header does not exist in the response, the header will be added to the response.
Delete
The header will be deleted from the response.
- Set the header parameter and value.
Example Value
Content-Disposition
Starts a download on the client side and specifies the name of the file to be downloaded.
Value requirements: Enter 1 to 2,000 characters. For a typical configuration, see the example on the right.
attachment;filename=FileName.xls
Content-Language
Specifies the language of the response page of the client.
zh-CN
en-US
Specifies the foreign domain URLs (request sources) that are allowed to access the resource in CORS.
Value requirements:- Enter up to 66 URLs.
- Wildcard domain names are supported.
- Enter up to 2,000 characters.
- Separate URLs with commas (,).
- Start with http:// or https://.
- If this is set to *, no URLs are allowed after the wildcard (*).
- Domain names with port numbers are supported.
- The value can be null, which is case-insensitive.
Example 1:
https://www.example.com
Example 2:
Example 3:
https://www.example.com,https://www.example01.com,https://*.abc.com
Timing-Allow-Origin
This parameter is used together with Access-Control-Allow-Origin to add dynamic, time-based control to CORS.
Example 1:
Example 2:
Specifies the HTTP request methods that can be used in a CORS request.
Value requirements: Enter 1 to 2,000 characters. Separate methods by commas (,).
GET,POST,HEAD
Specifies how long to cache the results of CORS preflight requests on specific resources.
Value requirements: This value is expressed in seconds and ranges from 0 to 1,000,000,000.
86400
Specifies the response header information visible to the client for a CORS request.
Value requirements: Enter 1 to 2,000 characters. Multiple headers can be configured at the same time. Separate them by commas (,).
Content-Length,Content-Encoding
Access-Control-Allow-Headers
Specifies the fields that can be carried in a cross-domain request.
Value requirements: Enter 1 to 2,000 characters. Multiple fields can be configured at the same time. Separate them by commas (,).
X- Custom-Header
Custom
Customized response header information. A response header starts with a letter and contains 1 to 100 characters, including letters, digits, and hyphens (-).
Value requirements: Enter 1 to 2,000 characters, which can contain letters, digits, spaces, and the following special characters: .-_*#!&+|^~'"/:;,=@?<>
NOTE:- If the custom parameter is Cache-Control, the value can be public, private, no-cache, no-store, no-transform, only-if-cached, proxy-revalidate, must-revalidate, immutable, max-age=***, stale-while-revalidate=***, s-maxage=***, stale-if-error=***, or min-fresh=*** (*** is a number). Enter up to 10 values and separate them by commas (,).
- The value of the Cache-Control header may affect the PoP cache.
x-testcdn
- Click OK.
- If your domain name has special configurations, Content-Type, Expires, Vary, or Cache-Control cannot be configured.
- The following response headers can only be modified. Response Header Operation cannot be set to Delete for them.
Content-Base
Content-Type
Server
Content-Language
Cache-Control
Expires
- CDN does not support the following response headers.
a_dynamic
upgrade
content-md5
accept-ranges
meter
content-range
keep-alive
www-authenticate
date
allow
proxy-authenticate
range
set-cookie
connection
etag
authentication-info
content-encoding
retry-after
last-modified
proxy-authorization
error
location
content-length
if-modified-since
transfer-encoding
content-location
host
Helpful Links
