Status Codes
You can view status codes returned to requests to all domain names (excluding those deleted if you have enabled the enterprise project function).
- Data of the past 90 days can be queried, and each query can include data of up to 31 days.
- If no data is available within the queried time range, no data is displayed in the list of status codes.
- The minimum granularity is 5 minutes. If the query time range is 8 days or longer, the minimum granularity is 4 hours.
- You can export the query results.
- You can filter domain names by tag or service type.
If the service area of your domain name is Global, you must query the statistics of this domain name by choosing Chinese mainland and International respectively. Query by Global is not available.
- Log in to Huawei Cloud console. Choose .
The CDN console is displayed.
- In the navigation pane, choose .
- Set search criteria to query the following data:
- Status Codes Overview: displays the number of each status code over time.
You can click legend entries, for example,
, to hide or display the statistics of specific codes. Statistics are collected on status codes, including 2XX, 3XX, 4XX, and 5XX.
Status Code
2XX
Success. A request has been accepted and processed by the server.
3XX
Redirection. The client needs to perform further operations to complete the request.
4XX
Client error. There was an error on the client side, including but not limited to syntax errors or failure to complete the request.
5XX
Server error. There was an error when the server was processing the request.
- Status Code Statistics: displays the number and proportion of different status codes for specific domain names.
You can click Appearances or Percentage in the table heading of the statistics details list to view the corresponding data in ascending or descending order.
