On this page
Show all
To Doris
Updated on 2024-12-02 GMT+08:00
Table 1 lists the destination job parameters when the destination link is a Doris link.
Table 1 Parameter description
Type
Example Value
Basic parameters
Schema/Tablespace
Name of the database to which data will be written. The schema can be automatically created. Click the icon next to the text box to select a schema or tablespace.
schema
Table Name
Name of the table to which data will be written. Click the icon next to the text box. The dialog box for selecting the table is displayed.
This parameter can be configured as a macro variable of date and time and a path name can contain multiple macro variables. When the macro variable of date and time works with a scheduled job, the incremental data can be synchronized periodically. For details, see Incremental Synchronization Using the Macro Variables of Date and Time.
If you have configured a macro variable of date and time and schedule a CDM job through DataArts Factory of DataArts Studio, the system replaces the macro variable of date and time with (Planned start time of the data development jobOffset) rather than (Actual start time of the CDM jobOffset).
table
Clear Data Before Import
Whether to clear the data in the destination table before data import. The options are as follows:
  • Do not clear: The data in the destination table is not cleared before data import. The imported data is just added to the table.
  • Clear all data: All data is cleared from the destination table before data import.
  • Clear part of data: Part of the data in the destination table is cleared before data import. If you select Clear part of data, you must configure WHERE Clause to specify which part will be deleted.
Clear part of data
WHERE Clause
If Clear Data Before Import is set to Clear part of data, data in the destination table will be deleted based on the WHERE clause after the configuration is complete and before the import starts.
age > 18 and age <= 60
stream load config properties
Stream load parameters
max_filter_ratio=0
Number of failed retries
Maximum number of retries upon a failure
3
Advanced attributes
Prepare for Data Import
The SQL statement that is first executed before a task is executed. Currently, only one SQL statement can be executed in wizard mode.
create temp table
Complete Statement After Data Import
The SQL statement that is executed after a task is executed. Currently, only one SQL statement can be executed.
merge into
Loader Threads
Number of threads started in each loader. A larger number allows more concurrent write operations.
The unique model or aggregation function replace have requirements on the insertion sequence. When they are used, do not use the concurrency capability.
Conflict handling policies do not support "replace into" or "on duplicate key update".
