- What's New
- Function Overview
- Getting Started
User Guide
- Permissions Management
- Supported Data Sources
- Creating and Managing a CDM Cluster
Creating a Link in a CDM Cluster
- Creating a Link Between CDM and a Data Source
Configuring Link Parameters
- OBS Link Parameters
- PostgreSQL/SQLServer Link Parameters
- GaussDB(DWS) Link Parameters
- RDS for MySQL/MySQL Database Link Parameters
- Oracle Database Link Parameters
- DLI Link Parameters
- Hive Link Parameters
- HBase Link Parameters
- HDFS Link Parameters
- FTP/SFTP Link Parameters
- Redis Link Parameters
- DDS Link Parameters
- CloudTable Link Parameters
- MongoDB Link Parameters
- Cassandra Link Parameters
- DIS Link Parameters
- Kafka Link Parameters
- DMS Kafka Link Parameters
- CSS Link Parameters
- Elasticsearch Link Parameters
- Dameng Database Link Parameters
- SAP HANA Link Parameters
- Shard Link Parameters
- MRS Hudi Link Parameters
- MRS ClickHouse Link Parameters
- ShenTong Database Link Parameters
- LogHub (SLS) Link Parameters
- Doris Link Parameters
- YASHAN Link Parameters
- Uploading a CDM Link Driver
- Creating a Hadoop Cluster Configuration
Creating a Job in a CDM Cluster
- Table/File Migration Jobs
- Creating an Entire Database Migration Job
Configuring CDM Source Job Parameters
- From OBS
- From HDFS
- From HBase/CloudTable
- From Hive
- From DLI
- From FTP/SFTP
- From HTTP
- From PostgreSQL/SQL Server
- From DWS
- From SAP HANA
- From MySQL
- From Oracle
- From a Database Shard
- From MongoDB/DDS
- From Redis
- From DIS
- From Kafka/DMS Kafka
- From Elasticsearch or CSS
- From MRS Hudi
- From MRS ClickHouse
- From a Dameng Database
- From LogHub (SLS)
- From a ShenTong Database
- From Doris
- From YASHAN
- Configuring CDM Destination Job Parameters
- Configuring CDM Job Field Mapping
- Configuring a Scheduled CDM Job
- Managing CDM Job Configuration
- Managing a CDM Job
- Managing CDM Jobs
- Viewing Traces
Key Operation Guide
- Incremental Migration
- Using Macro Variables of Date and Time
- Migration in Transaction Mode
- Encryption and Decryption During File Migration
- MD5 Verification
- Configuring Field Converters
- Adding Fields
- Migrating Files with Specified Names
- Regular Expressions for Separating Semi-structured Text
- Recording the Time When Data Is Written to the Database
- File Formats
- Converting Unsupported Data Types
Tutorials
- Creating an MRS Hive Link
- Creating a MySQL Link
- Migrating Data from MySQL to MRS Hive
- Migrating Data from MySQL to OBS
- Migrating Data from MySQL to DWS
- Migrating an Entire MySQL Database to RDS
- Migrating Data from Oracle to CSS
- Migrating Data from Oracle to DWS
- Migrating Data from OBS to CSS
- Migrating Data from OBS to DLI
- Migrating Data from MRS HDFS to OBS
- Migrating the Entire Elasticsearch Database to CSS
Best Practices
Tutorials
Advanced Data Migration Guidance
- MD5 Verification
- File Formats
- Scheduling a CDM Job by Transferring Parameters Using DataArts Factory
- Enabling Incremental Data Migration Through DataArts Factory
- Creating Table Migration Jobs in Batches Using CDM Nodes
- Simplified Migration of Trade Data to the Cloud and Analysis
- Migration of IoV Big Data to the Lake Without Loss
Tutorials
- Performance White Paper
- Security White Paper
API Reference
- Before You Start
- API Overview
- Calling APIs
- Application Example
API
Cluster Management
- Querying Cluster Details
- Deleting a Cluster
- Querying All AZs
- Querying Supported Versions
- Querying Version Specifications
- Querying Details About a Flavor
- Querying the Enterprise Project IDs of All Clusters
- Querying the Enterprise Project ID of a Specified Cluster
- Query a Specified Instance in a Cluster
- Modifying a Cluster
- Restarting a Cluster
- Starting a Cluster
- Stopping a Cluster (To Be Taken Offline)
- Creating a Cluster
- Querying the Cluster List
- Job Management
- Link Management
Cluster Management
- Public Data Structures
- Appendix
General
- What Are the Differences Between CDM and Other Data Migration Services?
- What Are the Advantages of CDM?
- What Are the Security Protection Mechanisms of CDM?
- How Do I Reduce the Cost of Using CDM?
- Will I Be Billed If My CDM Cluster Does Not Use the Data Transmission Function?
- Why Am I Billed Pay per Use When I Have Purchased a Yearly/Monthly CDM Incremental Package?
- How Do I Check the Remaining Validity Period of a Package?
- Will My Data Be Retained If My Package Expires or My Pay-per-Use Resources Are in Arrears?
- Can CDM Be Shared by Different Tenants?
- Can I Upgrade a CDM Cluster?
- How Is the Migration Performance of CDM?
- What Is the Number of Concurrent Jobs for Different CDM Cluster Versions?
- Can I Stop a CDM Cluster?
Functions
- Does CDM Support Incremental Data Migration?
- Does CDM Support Field Conversion?
- What Component Versions Are Recommended for Migrating Hadoop Data Sources?
- What Data Formats Are Supported When the Data Source Is Hive?
- Can I Synchronize Jobs to Other Clusters?
- Can I Create Jobs in Batches?
- Can I Schedule Jobs in Batches?
- How Do I Back Up CDM Jobs?
- What Should I Do If Only Some Nodes in a HANA Cluster Can Communicate with the CDM Cluster?
- How Do I Use Java to Invoke CDM RESTful APIs to Create Data Migration Jobs?
- How Do I Connect the On-Premises Intranet or Third-Party Private Network to CDM?
- Does CDM Support Parameters or Variables?
- How Do I Set the Number of Concurrent Extractors for a CDM Migration Job?
- Does CDM Support Real-Time Migration of Dynamic Data?
- Can I Stop CDM Clusters?
- How Do I Obtain the Current Time Using an Expression?
- What Is the Time Format for the Where Clause Parameters for Creating a Migration Job?
- Can CDM Migrate Field Comments from a Source Table to a Destination Table?
Troubleshooting
- What Should I Do If the Log Prompts that the Date Format Fails to Be Parsed?
- What Can I Do If the Map Field Tab Page Cannot Display All Columns?
- How Do I Select Distribution Columns When Using CDM to Migrate Data to GaussDB(DWS)?
- What Do I Do If the Error Message "value too long for type character varying" Is Displayed When I Migrate Data to DWS?
- What Can I Do If Error Message "Unable to execute the SQL statement" Is Displayed When I Import Data from OBS to SQL Server?
- What Should I Do If the Cluster List Is Empty, I Have No Access Permission, or My Operation Is Denied?
- Why Is Error ORA-01555 Reported During Migration from Oracle to DWS?
- What Should I Do If the MongoDB Connection Migration Fails?
- What Should I Do If a Hive Migration Job Is Suspended for a Long Period of Time?
- What Should I Do If an Error Is Reported Because the Field Type Mapping Does Not Match During Data Migration Using CDM?
- What Should I Do If a JDBC Connection Timeout Error Is Reported During MySQL Migration?
- What Should I Do If a CDM Migration Job Fails After a Link from Hive to GaussDB(DWS) Is Created?
- How Do I Use CDM to Export MySQL Data to an SQL File and Upload the File to an OBS Bucket?
- What Should I Do If CDM Fails to Migrate Data from OBS to DLI?
- What Should I Do If Error "Configuration Item [linkConfig.createBackendLinks] Does Not Exist" or "Configuration Item [throttlingConfig.concurrentSubJobs] Does Not Exist" Is Reported?
- What Should I Do If Message "CORE_0031:Connect time out. (Cdm.0523)" Is Displayed During the Creation of an MRS Hive Link?
- What Should I Do If Message "CDM Does Not Support Auto Creation of an Empty Table with No Column" Is Displayed When I Enable Auto Table Creation?
- What Should I Do If I Cannot Obtain the Schema Name When Creating an Oracle Relational Database Migration Job?
- What Should I Do If invalid input syntax for integer: "true" Is Displayed During MySQL Database Migration?
- What Should I Do If the Migration Source Is Oracle and Error Message "snapshot too old" Is Displayed?
- What Should I Do If Error "Identifier name is too long" Is Reported During Entire DB Migration to Hive?
- What Should I Do If Data Is Lost During Migration to DLI?
- What Should I Do If the Oracle Link Connectivity Test Is Successful on the Link Creation Page but Fails on the Links Page?
- What Should I Do If Destination Fields Are Not Displayed When Auto Table Creation Is Enabled in the Destination Job Configuration?
- What Should I Do If a Job Exported from a Cluster Fails to Be Imported to Another Cluster?
- What Should I Do If an Error Message Is Displayed Indicating that the Block Is Missing During HDFS File Migration?
- What Should I Do If the CDM Job Management Page Cannot Be Accessed and a Message Is Displayed Indicating that the Network or Server Cannot Be Accessed?
- What Should I Do If a CDM Cluster of Version 2.8.6 Fails to Migrate Data from OBS to DLI?
- What Should I Do If Error Message "Read timed out" Is Displayed During DWS Data Migration?
- What Should I Do If No Database or Table Information Can Be Obtained Through a Hive Link?
- What Should I Do If Error "get filesystem" Is Reported During the Creation of a FusionInsight HDFS Link?
- What Should I Do If Error "Invoke DLI service api failed" Is Reported When the Data Migration from MySQL to DLI Is About to Complete?
- What Should I Do If a MongoDB Field Fails to Be Migrated to the Destination?
- What Should I Do If a Field Is Escaped and Contains a Backslash (\) During the Migration of a DLI Foreign Table (OBS File) to DWS?
- What Should I Do If "Error occurs during loader run" Is Reported During Migration from PostgreSQL to Hive?
- What Should I Do If Error Message "Lost connection to MySQL server during query" Is Displayed During Migration from MySQL to DWS?
- What Should I Do If Error Message "For input string: "false" Is Displayed During Field Type Conversion During MySQL-to-DLI Migration?
- What Should I Do If an Error Occurs During the Migration of TINYINT Data from MySQL to DWS?
- What Should I Do If the Data Volume Is Inconsistent Before and After Data Migration?
- What Should I Do If an Error Is Reported Indicating an Incorrect Username or Password During Link Creation but They Are Correct Indeed?
- What Should I Do If a Message Is Displayed Indicating that the Fields in the Lower Camel Case Do Not Exist During Data Migration from a Database to OBS?
- What Should I Do If Error "invalid utf-8 character string" Is Reported When CSV Data Is Inserted into the MySQL Database?
- What Should I Do If a Scheduled Job Fails and Link Connectivity Is Abnormal?
- What Should I Do If CSV Data Fails to Be Inserted into a MySQL Database?
- What Should I Do If Error "timeout waiting for connection from pool" Is Reported During ES Writing?
- What Should I Do If the FTP Connectivity Test Fails and an Internal Server Error Is Reported?
- What Should I Do If All Users Except User root Cannot Access RDS for MySQL?
General
To DWS
If the destination link of a job is a DWS link, configure the destination job parameters based on Table 1.
Parameter |
Description |
Example Value |
Schema/Tablespace |
Name of the database to which data will be written. The schema can be automatically created. Click the icon next to the text box to select a schema or tablespace. |
schema |
Auto Table Creation |
This parameter is displayed only when the source is a relational database. The options are as follows:
Field Mapping in Automatic Table Creation on DWS describes the field mapping between the DWS tables created by CDM and source tables. Only column comments are synchronized during automatic table creation. Table comments are not synchronized. |
Non-auto creation |
Table Name |
Name of the table to which data will be written. Click the icon next to the text box. The dialog box for selecting the table is displayed. This parameter can be configured as a macro variable of date and time and a path name can contain multiple macro variables. When the macro variable of date and time works with a scheduled job, the incremental data can be synchronized periodically. For details, see Incremental Synchronization Using the Macro Variables of Date and Time. If you have configured a macro variable of date and time and schedule a CDM job through DataArts Studio DataArts Factory, the system replaces the macro variable of date and time with (Planned start time of the data development job – Offset) rather than (Actual start time of the CDM job – Offset). |
table |
Compress Data |
Whether to compress data when data is imported to DWS and Auto creation is selected |
No |
Storage Mode |
When data is imported to DWS and Auto Creation is selected, you can specify the data storage mode:
Row-based |
Import Mode |
Mode for importing data to DWS
COPY |
Clear Data Before Import |
Whether to clear the data in the destination table before data import. The options are as follows:
Clear part of data |
WHERE Clause |
If Clear Data Before Import is set to Clear part of data, data in the destination table will be deleted based on the WHERE clause after the configuration is complete and before the import starts. |
age > 18 and age <= 60 |
Import to Staging Table |
If you set this parameter to Yes, the transaction mode is enabled. CDM automatically creates a temporary table and imports data to the temporary table. After the data is imported successfully, it is migrated to the destination table in transaction mode. If the import fails, the destination table is rolled back to the state before the job starts. . The default value is No, indicating that CDM directly imports the data to the destination table. In this case, if the job fails to be executed, the data that has been imported to the destination table will not be rolled back automatically. If you select Clear part of data or Clear all data for Clear Data Before Import, CDM does not roll back the deleted data in transaction mode. |
No |
Extending field length |
When Auto creation is selected, the length of the character fields can be extended to three times the original length and then written to the destination table. If the encoding types of the source and destination databases are different, but the character fields in the source and destination tables are the same, errors may occur during data migration due to character length difference. When a character field containing Chinese characters is imported to DWS, the length of the character field must be automatically increased by three times. If a job fails to be executed and an error message similar to value too long for type character varying exists in the log when you import Chinese characters to DWS, you can enable this function to solve the problem. When this function is enabled, some fields consume three times the storage space of the user. |
No |
Use NOT NULL Constraint |
If you choose to create a target table automatically and specify the NOT NULL constraint, keep the NOT NULL constraints of the source and target tables consistent. |
Yes |
Prepare for Data Import |
The SQL statement that is first executed before a task is executed. Currently, only one SQL statement can be executed in wizard mode. |
create temp table |
Complete Statement After Data Import |
The SQL statement that is executed after a task is executed. Currently, only one SQL statement can be executed. |
merge into |
Loader Threads |
Number of threads started in each loader. A larger number allows more concurrent write operations. |
1 |
Figure 1 describes the field mapping between DWS tables created by CDM and source tables. For example, if you use CDM to migrate the Oracle database to DWS, CDM automatically creates a table on DWS and maps the NUMBER(3,0) field of the Oracle database to the SMALLINT field of DWS.
Indexes cannot be created in automatic table creation scenarios.
